Thread: crane cams?
05-19-2008, 10:48 PM #1Member
- Oct 2007
- Union Beach, NJ
triple black- 02 z28 m6
crane cams?
anyone know if crane quick lift cams are outdated? im looking at the 224/224 .551 lift 114 lsa. website claims fair, moderately choppy idle. Ill be using cranes variable rockers and et performance heads. compression should be around 11.0.
05-19-2008, 10:57 PM #2
You should call them up. They have actually came out with alot of new grinds due to R&D. Plus that way you can get the exact cam to your car and needs. Alot of time they will join 2 off the shelf grinds in one for your combo.
Crane Cams Tech. 386-258-6174Don't be afraid of the bottle!!! Be afraid of your tune!!!
05-20-2008, 12:05 AM #3Member
- Oct 2007
- Union Beach, NJ
thanks a lot.
05-20-2008, 12:08 AM #4
No problem. I think the guy you want to talk to is Dave. I can't remember but I'm pretty sure that is the LS specialist.
05-21-2008, 06:10 AM #5
not outdated yet. they actually have a new lobe design called the LSHS. i am using those in my motor. also, i use the 1.8 shaft rockers.
here was a test vinci high performance did a couple of years ago. a comp cam 220/224 .581/.581 115 LSA with 1.7 crane rockers versus a 216/224 .551/.551 113 LSA with crane 1.8 rockers (brings total lift to .583/.583). using the smaller duration cam with higher ratio rockers made more overall power.
r.i.p. crane cams
By 0verkill in forum Almost Anything GoesReplies: 16Last Post: 06-16-2009, 09:11 PM -
Crane Cams Out of Business
By Sarge in forum Almost Anything GoesReplies: 39Last Post: 06-15-2009, 04:19 AM -
Crane Cams.......................is history.....
By fxgs in forum Almost Anything GoesReplies: 14Last Post: 06-15-2009, 04:18 AM -
Crane Cams Liquidating!!!
By 6.0LiterImportEater in forum GTOReplies: 0Last Post: 03-26-2009, 03:39 PM -
Crane Cams write up.
By aquickbird in forum Internal EngineReplies: 24Last Post: 01-09-2008, 12:02 AM
