Results 1 to 3 of 3
06-17-2008, 06:19 PM #1HOUDINI'S RIDE
- GA
- iTrader
- 2 (100%)
BLUE- Z28/SS
crane cams/ vinci power programmer
Hey all heres a great programmer works on the following cars
programmer # 1202-008
99-04 corvette ls1/ls6
99-02 camaro / firebird
this has just been reflashed and is unlocked for any car listed above...these things are over $400 dollars new but this one is lower than that it has alot of things you can tune on your car Delivers up to 30 HP rear-wheel increase from stock! I'll do $365.00 shipped pm me if your interested in it.........thanks heres straight form the site info on it below......
Delivers up to 35 Ft. Lbs. rear-wheel torque increase from stock!
Easy Plug-n-Go installation takes only minutes!
Easy push-button, hand-held programming. No laptop computer required!! Lets you recalibrate for taller/shorter tires, 25" to 44" on most trucks!
Lets you recalibrate for higher/lower (numerical) rear axle ratio from 2.73 to 5.13 for most applications!
Allows you to match speed limiter to the speed rating of tires!
Provides 30+ different tuning parameters for stock engines (most trucks)!Provides tuning for three Crane Powermax Truck-Power cam profiles plus allows tuning for stock cam!
Allows adjustment of idle speed in 50 RPM increments!
Optimizes transmission shift points for new Powermax Truck-Power cams!
Lets you choose shift points for stock cams!
Calibrated for all truck auto transmissions including Allison 5-speed!
Allows tuning of high-flow injectors for supercharged applications!
Lets you ?fine tune? your spark advance curve plus-or-minus 10% from the Power-Tuner programmed curve that you select!
Delivers performance increases without changing to colder thermostat and harming fuel economy!
Lets you adjust to your grade of fuel: Low, middle, or high octane, with auto adjustment if low grade fuel is accidentally used in high octane mode!
Easy return-to-stock anytime you choose!
Performance settings can be infinitely changed!
PowerMax Power-Tuner is specifically calibrated to your specific vehicle!
Reads diagnostic trouble codes and provides easy "clear code" function!
06-21-2008, 12:06 AM #2HOUDINI'S RIDE
- GA
- iTrader
- 2 (100%)
BLUE- Z28/SS
Price Dropped $185.00
06-22-2008, 01:52 PM #3HOUDINI'S RIDE
- GA
- iTrader
- 2 (100%)
BLUE- Z28/SS
pending Sale!
FOR SALE: Vinci Power Programmer/Tuner
By Firebirdjones in forum Parts For Sale / TradeReplies: 11Last Post: 07-18-2008, 10:39 PM -
F/S Crane Cams Power tuner
By sneaky7980 in forum Parts For Sale / TradeReplies: 3Last Post: 03-09-2008, 08:11 PM -
Crane Cams Power Tuner Question?
By Sunset T/A in forum Computer & TuningReplies: 1Last Post: 12-10-2007, 07:31 PM -
VINCI VHP Crane Programmer Tuner $250 Used
By baesvt in forum Parts For Sale / TradeReplies: 0Last Post: 03-15-2007, 08:37 PM
