Results 1 to 20 of 25
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Exclamation Parking brake(e-brake)
    Has anyone changed the shoes on these and how big of an issue is it... mine sqeeks and you have to click in pretty high up for it to lock... and i tend to pull it while driving around corners etc etc... Anyway Im getting new rear brake rotors and pads soon and i want the brakes to be 100 percent since i replaced the front rotors and pads last night.
    .. Im getting new plugs...wires... tires..lid... and decals after this...
    nothing beats a good brake job first tho
    Puerto Rico LS1 Rikki_SeVeN's Avatar
    Puerto Rico
    1999 Camaro Z28 A4
    +1... I just changed my Front Brakes too... I wanna know how to deal with the Rear and the E-brake...
    NeW YoRk
    2001 ws6
    what is this tokyo drift?
    Puerto Rico
    1999 Camaro Z28 A4
    ... almost the same thing I thought off when I read the Original Post...
    Cookie Monster LukesSpeedShop's Avatar
    Watertown, New York
    2002 Z28
    The ebrake is just a drum brake set-up, inside of the disc rotor. These almost never get wore out unless you do things like putting the ebrake on around corners to do toyko drift. I you dont know how to adust them then you better goto a mechanic to get it done.
    Puerto Rico
    1999 Camaro Z28 A4
    Quote Originally Posted by kingdaveofblair View Post
    Nice, great Idea... btw... PepBoys and Advanced both said...the computer didn't show any "Pads" for a Drum inside the Disk at all... so that confused me
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by Rikki_SeVeN View Post
    Advance has them under "Brakes > Parking Brake Shoes". The guy was probably looking in the subcategory "Brake Pads: Rear" and therefore couldn't find them. They are quite expensive if I remember right, something like $70.
    Puerto Rico
    1999 Camaro Z28 A4
    Quote Originally Posted by Wesman View Post
    holly crap... the front ones in PepBoys Ceramic, were only like $55
    NJ
    SGM
    1998 Trans Am WS6
    Yes, front and rear pads are about that much. The e-brake shoes are much more expensive for some reason, though.
    Arizona
    Huh???? There are no brake shoes for the parking brakes on these 4th gens. Its simply is a cable that uses the pads that are already there. You apply the brake and it uses the existing caliper/pad assembly.
    Puerto Rico
    1999 Camaro Z28 A4
    that's exactly what they told me there... (dude owned a LT1)
    Arizona
    You are thinking of the older setups,,,,something like what is used on my 71 corvette,,,,it actually has tiny brake shoes inside the rear rotor/hub assembly,,,,pain in the arse to work on,,,,and if not used on a regular basis they tend to freeze up,,,common problem which is why I think GM got away from this design many years ago.
    Arizona
    That is correct,,,I have both an LT1 and an LS1 F-body,,,,both use the more conventional caliper/pad assembly for the e-brake.
    Puerto Rico
    1999 Camaro Z28 A4
    I saw a Grand AM GT same year as my car...that had that exact assembly in the back...that's why I thought mine was the same
    NJ
    SGM
    1998 Trans Am WS6
    You know what you are right...I completely forgot that, and I should have known considering I took the entire rear apart to have the gears set up
    It did say they they had shoes for it at the Advance Auto though...probably just one of many errors in our system. I'll have to check it next time I'm in and have it fixed if its still listed.
    Puerto Rico
    1999 Camaro Z28 A4
    I just keep getting more and more confused... I mean... I'm probably just gonna lift my car tomorow...and take off one of the rear wheels and scope it out for myself... and see who's right!
    Beaver Dam KY
    79 T/A -91 Firebird
    haha take my car to a mechanic is simple.. i just pull it in my shop..lol.
    NeW YoRk
    2001 ws6
    still not sure why you treat your trans am like a civic?
    doylestown, Pa
    SILVER
    2004 CTS-V
    So your LT1 and LS1 F-Bodys have the same break setup??????????
    Are you sure? You should double check cause 97 was the last year to use the caliper for an E-Brake. 98 on up use a drum setup for the E-Brake!!
    NJ
    SGM
    1998 Trans Am WS6
    I'm getting more and more confused here...
  1. Question: parking brake
    By jodmari in forum Firebird / WS6
    Last Post: 12-23-2015, 03:27 AM
  2. Parking Brake "Brake" light not turning on
    By Questioner in forum Firebird / WS6
    Last Post: 11-05-2015, 06:52 AM
  3. parking brake
    By slimss in forum GM Trucks
    Last Post: 04-26-2012, 07:59 AM
  4. Parking brake
    By c5z28 in forum General Help
    Last Post: 12-07-2010, 02:56 PM
  5. dvd parking brake
    By slipping in forum Stereo and Electronics
    Last Post: 12-21-2006, 05:59 PM
