Results 1 to 16 of 16
Thread: not accelerating smooth
11-23-2005, 08:24 AM #1
- Rockford IL
Black- 1999 Firehawk Trans Am
my car doesn't accelerate smoothly. always use 93 and just had oil change. wondering if it is k n oil on MAF. help
11-23-2005, 09:11 AM #2
Need a little more info.....you have a A4 or stick? Is the car jerking, hesitating, slipping...what?
11-24-2005, 08:02 AM #3
- Rockford IL
it is a stick. when i accelerate it takes a half second to get going. this happens in any gear and some times it doesn't happen. it is like it is catching its breath. brand new clutch. this was happening b4 and after the new clutch.
11-24-2005, 09:37 AM #4
- THE SWAMP
Is your K&N air filter clean? Clean your MAF sensor with electrical cleaner, and while you've got that off, clean the inside of your throttle body. Now is also a good time to reset your car's computer.
Other considerations are fuel and ignition. When was the last time you changed your fuel filter? Or cleaned your injectors? How about spark plugs (& wires)? Have they ever been changed? Since your car is six years old, if these haven't been done, it's time to do them as well.
11-24-2005, 11:07 PM #5
- Sep 2005
- New York, NY
Collectors Edition Yellow- 2002 Pontiac Trans AM WS6
Originally Posted by GatorSS
sounds like some sort of throttle or mixture problem.... As gatorSS said check everything!!! Get some fuel injection cleaner to clean out the injectors.... Then if it's not the problem they could use cleaning.... And also check the throttle body flap on the inside... It's quite possible that the flap has some residue on it that will cause it to stick just enough to cause lag in acceleration.. Hey it's worth a shot...
11-25-2005, 08:37 AM #6
- Rockford IL
thanks guys .
11-25-2005, 08:46 AM #7
- THE SWAMP
You're welcome. Oh, and welcome aboard.
11-25-2005, 09:42 AM #8
- orange*county, ca.
Black- 2001 Pontiac Trans Am WS6
i get the same "hesitation".......it happens at like 1500-1800 rpms....
2001 Trans Am WS6 #4925 built/tuned by CMS
11-28-2005, 07:16 AM #9
- Rockford IL
yep that s about right 1800rpms. btw how do u reset computer. thanks
11-30-2005, 07:15 PM #10
I think you have to hold the key down in the"acc" position for like seven seconds...i'm not sure, it's in the owner's manual though.
12-02-2005, 05:36 PM #11
Originally Posted by 01black
GM released a bulletin regarding the used of oiled filters in A4 cars. The accleration issues were fucking up the trannys somehow.. i dont remember exactly....
12-02-2005, 05:41 PM #1299PontTAGuest
Originally Posted by whoa guy
12-03-2005, 03:57 PM #13
- Rockford IL
well i cleaned the maf but it is still happening right around 2500rpms. does anyone know how to reset the computer. couldn't find it in the manual.
12-03-2005, 04:37 PM #14
- Sep 2005
- Pueblo, Colorado
Black- 1998 Pontiac Trans Am
Turn key on but don't start car.
Pull PCM BAT and PCM IGN fuses in engine compartment fuse boxes.
Wait like 5-10 minutes
Turn ignition off.
Replace fuses
I would highly recommend replacing the fuel filter if you havent done so. it only takes like 10 minutes. Just make sure you dont have your mouth open.
12-03-2005, 08:47 PM #15
It's actually better to disconnect the batt to clear the comp. Put the ignition to run but don't start it...disconnect battery and let sit for 10 mintues. That completely clears the comp and any stored energy that maintains memory. Take key out and reconnect the batt...there's also a certain driving procedure you have to do. Here's the link http://obdii.com/drivecycle.html
12-04-2005, 05:59 PM #16
- THE SWAMP
We've been through this before. Here you go:
http://www.ls1.com/forums/showthread.php?t=6054
Help: noise when accelerating
By j nix in forum DrivetrainReplies: 27Last Post: 09-25-2011, 10:41 AM -
By 79Firebird_99TA in forum Automatic TransmissionReplies: 7Last Post: 06-30-2011, 04:03 PM -
Question: rattle noise when accelerating
By dav-02ws6-m6 in forum General HelpReplies: 11Last Post: 11-28-2010, 07:28 PM -
I have no idea accelerating problem
By FutureWS6 in forum General HelpReplies: 14Last Post: 10-23-2009, 05:10 PM -
Help!!accelerating Causes Ses Flashing
By IZNUTHN in forum General HelpReplies: 18Last Post: 12-09-2005, 04:51 AM
