Thread: rattle noise when accelerating
11-27-2010, 04:20 PM #1
11-27-2010, 04:42 PM #2
do you have larger than stock exhaust? and does it do this in gear, if you have the e brake on and put it in gear and rev a little does it make the same noise? if so I would get some one to watch the engine when you do it, might be bad motor mounts.
11-27-2010, 05:00 PM #3
it has the slp Y-pipe and 3" pipe to the muffler. it does it when ever i put it on reverse and on first gear when taking off on low rpms.
11-27-2010, 05:15 PM #4
i would check the motor mounts, thats the problem i had with my 3" exhaust. the motor mounts get worn out and the motor can move a lot taking the exhaust with it, banging it on the frame. I got me some poly mounts problem solved.
11-27-2010, 05:56 PM #5Senior Member
- Apr 2008
- Madison, WI
Any general idea where the noise is coming from? Kinda sounds like a loose spark plug, maybe an exhaust leak, or cracked flexplate? IDK, just throwing ideas out.
11-27-2010, 08:02 PM #6
the sound comes from underneth the shifter to the cup holder
11-27-2010, 09:50 PM #7Army Dude
- Nov 2007
- Ft. Rucker Area, Lower AL
Arctic White- 01 TA / 06 Duc 749D
Had a simular issue while I was home in Oct. Turned out to be a bad transmission mount. But my car is an A4, not sure if you have the same type mount or not. Check it out, also could be the TQ arm bushing is crap. Hope you find and fix it, GL with that.
11-28-2010, 07:52 AM #811 years of bangin gears
- Jan 2009
- North Jersey
If you have an 6 speed, it could be the shifter. I was reading my installation instructions from Hurst and apparently the shifter cup in the trans wears out over time. When my car had the B&M, I got a low RPM rattle in 1st going up hills from a dead stop. Now that I have the Hurst installed, the rattle seems to have gone away.
11-28-2010, 09:11 AM #9
thank you guy for all the answers. i am going try to lift the car up and check everything underneath, to make sure nothing is lose. I'll check the shifter too, i will let you guys know when i find something out.
Thanks.
11-28-2010, 10:10 AM #10Senior Member
- Apr 2008
- Madison, WI
if its a rattle in that area, then it could be an exhaust heat shield.
11-28-2010, 05:15 PM #11
that's something that i was thinking. but i wasn't sure it had one on that area. hopefully the next weekend i will jack the car up and check it out. it's very cold right now and not having a garage really sucks.
thanks.
11-28-2010, 07:28 PM #12
good luck on finding the problem
Clunking /rattle noise
By xenergyx in forum General HelpReplies: 6Last Post: 11-05-2014, 05:32 PM -
Noise when accelerating hard off line (recently lowered)
By 79Firebird_99TA in forum Suspension and HandlingReplies: 4Last Post: 04-12-2012, 06:15 AM -
Help: noise when accelerating
By j nix in forum DrivetrainReplies: 27Last Post: 09-25-2011, 10:41 AM -
By 79Firebird_99TA in forum Automatic TransmissionReplies: 7Last Post: 06-30-2011, 04:03 PM -
Accelerating problem and "popping noise"
By 94camm in forum General HelpReplies: 2Last Post: 10-05-2005, 08:38 AM
