Results 1 to 20 of 28
Thread: noise when accelerating
05-22-2011, 03:37 PM #1Last of the Breed
- Sep 2010
- Farmington Hills, MI
Navy Blue Metallic- 2002 Trans Am WS6 NBM
When I accelerate quickly while the car is already moving, I get a shaky squeak that comes from the rear of the car. It only happens when I accelerate hard, as far as I can tell. And it does it every time. My sig shows what I have done to my car. The lowering and suspension stuff I just did. Not sure if the sound was there before. I would appreciate any help. Thanks everybody.
Diablo Sport Predator Performance Tune | TB Bypass | Bilstein HD Shocks | Eibach Pro Kit | UMI SFC | UMI Rear LCA's and brackets | UMI adj PHB, UMI Front/Rear Sway Bars |UMI Strut Tower Brace | SLP Lid | SLP Loud Mouth with quad tips | High output alt
05-23-2011, 02:59 PM #2Last of the Breed
- Sep 2010
No one
Really, no one has any advice on what I could be looking for? I really need some help before I break something.
05-23-2011, 03:52 PM #3None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
I would start by checking all the bolts for the suspension - lower control arms, panhard bar, torque arm, ect., and make sure none are loose and tightened to proper specs. Check to make sure the springs are seated properly. After that, I would move on to checking drivetrain componants.
05-23-2011, 07:24 PM #4
05-23-2011, 08:54 PM #5
sometimes the rubber isolator that sits on top of the spring move out of place and it causes the spring to not seat right. Same thing at the bottom of the spring were it meets with the rear end. Also check that the rubber isolator are in good shape. There is a small rubber bushing that sits on top of the rear shocks and the floor of the car. If those bushings are adjusted properly they can break and cause knocking noise when you drive around.
05-23-2011, 10:33 PM #6
Looked at your suspension thread and see you got all polyurethane, rod ends are known to be noisy. On top of the springs i'd re-check the sfc's. Then again if it only does it under hard acceleration it could be axle hop. Those lowering springs and will have thrown off the pinion angle, and the relocation brackets will aggravate the problem(more grip). If you have the time replace the rear springs and see if that fixes it, then you know you need an adjustable torque arm.
05-24-2011, 02:43 AM #7
05-24-2011, 04:12 AM #8Last of the Breed
- Sep 2010
That's why I love this forum. Thanks guys. With everything said I just wanted to add that there is no noticeable shake or vibration, just the Squeek. Which goes away as soon as I deccelerate. I don't seem to get any wheel hop. It usually happens when I am going like 50 or 60 and floor it. It's weird too that it the Squeek sounds like it is from something shaking, but I would be going straight. Don't know if this helps pin point the problem any more. I greased everything with an aluminum complex instead of silicone based grease. Would that make a difference?
05-30-2011, 02:47 PM #9Last of the Breed
- Sep 2010
SO it sounds like I should re tighten all my suspension/chassis parts to spec, install an adj Torque Arm and see what happens. I was wondering if it could just be my hatch? What do you think and how could I check if it is?
05-30-2011, 03:42 PM #10
Check the rear joint at the shaft, sounds like it was neglected of being greased
05-31-2011, 02:44 AM #11Last of the Breed
- Sep 2010
Can I ruin any of my greasable suspension parts by over greasing?
05-31-2011, 04:31 PM #12
You can by mix matching some greases, don't know about over greasing.
06-01-2011, 03:17 AM #13Last of the Breed
- Sep 2010
I am thinking maybe since I just installed new suspension parts that I might not have greased them enough. The directions for the parts said don't over grease, so I was conservative. I can't see how it would hurt them. I am trying to get in the garage to retighten and regrease and go from there. I will post what I find. What kind of grease should I use on my hatch latch. I know those have a dendency to squeek.
06-18-2011, 04:28 PM #14Last of the Breed
- Sep 2010
So I went and loosened and retorqued down all my new suspension parts and the squeaking is still there. I have noticed that the squeaking is not only when I accelerate, but just squeaks periodically now. Any other ideas. Because it is squeaking, i think that there is something wrong that might cause more problems in the future. Any hep would be appreciated.
06-19-2011, 07:33 AM #15
Did you check the rear u-joint ? Depending what you're greasing will depend on the grease.
U-joints will last with a high temp, high pressure style grease, the best choice would also be a marine grade syn grease (Lucas), while ball joints will be fine with a regular grease, bushings made of rubber you never use a oil based grease but a silicone base
06-19-2011, 08:33 AM #16
I don't think it's been said, but when you lower your car, your exhaust gets really close to the upper pan hard bar support where it goes over the axle. Yours may be contacting there and making that "squeak" noise as you put it. I would definitely check this out as well before doing anything more involved labor wise.
06-19-2011, 06:38 PM #17Last of the Breed
- Sep 2010
I didn't grease the u-joint yet, but I will. I wish I would have gotten the silicone grease from UMI when I got my suspension parts. I am using a non lithium, aluminum base Extreme Pressure grease from Amsoil. They sell this stuff to the fire depts for there fire trucks.
06-19-2011, 06:44 PM #18
06-22-2011, 04:40 AM #19Mustang Eater
- Feb 2010
- Springfield, Missouri, United
Maroon- 2000 z28 6 speed
i had a parrot stuck in my torque bar. drove through the amazon lately?
2001 B4C Totaled 4/25/11
2000 Z28 M6 Cammed N' Slammed (SVT KLR)
09-23-2011, 05:23 PM #20Last of the Breed
- Sep 2010
My noise still hasn't been pin pointed. Any time I drive over 80 mph it will Squeek. When I decelerate it goes away. It also squeaks when I go wot. It seems to be getting worse. It is coming from the trunk. I greased everything and tightened everything. I didn't re tighten the bolts on the top of my rear shocks, should I check those? Should I just replace my torque arm for n adjustable and a relo bracket?
Noise when accelerating hard off line (recently lowered)
By 79Firebird_99TA in forum Suspension and HandlingReplies: 4Last Post: 04-12-2012, 06:15 AM -
By 79Firebird_99TA in forum Automatic TransmissionReplies: 7Last Post: 06-30-2011, 04:03 PM -
Question: rattle noise when accelerating
By dav-02ws6-m6 in forum General HelpReplies: 11Last Post: 11-28-2010, 07:28 PM -
Help!!accelerating Causes Ses Flashing
By IZNUTHN in forum General HelpReplies: 18Last Post: 12-09-2005, 04:51 AM -
Accelerating problem and "popping noise"
By 94camm in forum General HelpReplies: 2Last Post: 10-05-2005, 08:38 AM
