Results 1 to 20 of 33
    2-Legit-2-Quit bgable's Avatar
    Cville,Indiana
    IBM
    2006 Pontiac GTO
    Question whats the deal with my turn signal?
    okay so ive replaced the passenger turn signal bulb twice and re sealed the lens deal same with the driver side and tonight the driver side turn signal stopped working? when i have my lights on the bulb it self works but the turn signal arrow just stays solid and doesnt flash and when the lights are of it doesnt come on at all and the arrow is once again solid? i figured if it was the bulb then it wouldnt come on when the lights are on either...i thought maybe wiring but who knows any idea's? sorry for rambling on but it makes me so mad
    Feb 2006
    2002 WS6
    The turn signal lamps are a duel filament bulb (it's been too long since I last looked though so don't quote me on that), one for DRL running lightts and one for turn, its very possible that the filament has simply burned out.
    Member whiteLS1TA's Avatar
    California
    Artic white
    2001 Trans am
    i had the same problem. check your blinker fluid
    Georgia
    2014 Camaro 1LS
    Quote Originally Posted by gable2000ta View Post
    The turn signal lamps are a duel filament bulb.........but if you already replaced them it might be the flasher.
    This might help you.........
    http://www.ls1.com/forums/showthread...rn+signal+work
    Georgia
    2014 Camaro 1LS
    Quote Originally Posted by whiteLS1TA View Post
    u get yours fixed ?
    California
    Artic white
    2001 Trans am
    u get yours fixed ?
    no not yet i think i need a flasher as well my sisters boyfriend had the same problem and he changed the flasher and the bulb. he told me i might as well do both sides
    Member 02WS6dream's Avatar
    Jun 2006
    Charlotte, NC
    2001 Trans Am WS6
    before you do that... this is a common problem that i've seen many threads on since i fixed mine. It could be your flasher i suppose... but more commonly the socket gets exposed to moisture due to these poorly designed housings that you say you have had to seal. Look at the socket that the bulb fits into for corrosion. I replaced the housings themselves, the sockets, and the bulbs. The only problem i've had since then (1 year) is that the sockets i bought were aftermarket and the bulb doesn't fit as snug as i'd like and has lost contact 2 or three times. Fixed by simply pushing the bulb in firmly; no more moisture or corrosion. I suggest you look into this before replacing the flasher.
    Senior Member 01ws6er's Avatar
    The 717
    2001 Trash Can
    Quote Originally Posted by 02WS6dream View Post
    Exactly what I was gonna say. Kept happenin to mine, I checked all the wiring/ circuitry and no deal. Went to my shop, and they cleaned out my sockets and no problems since. Cost me $15 bucks.
    sounds like a bad ground
    Jun 2006
    Charlotte, NC
    2001 Trans Am WS6
    before i replaced them, i was able to clean them out with some contact cleaner and eventually my dremel when it got bad and get a couple weeks out of them. The housings continued to allow moisture in though and they would just get corroded again--that's why i replaced everything. I guess these housings will eventually leak too, but now i know where to get them and how to fix the problem. was able to get new housings for 35 apiece.
    Junior Member 94TAGT's Avatar
    Fredericksburg,Virginia
    Sunfire Yellow
    1994 Trans Am GT
    I was having the same issue and it has since been resolved. As some may not know the 4th gen f-bodies have two flashers, one for the hazards and one for the signals. The signal flasher was my issue.
    Now for the socket. I did replace my left front turn signal socket as well due to damage to the old one. Luckily I have a Chevy dealership and a Buick/Pontiac dealership within 5 mins of me to buy parts from and I purchased a GM replacement socket and pigtail as opposed to the knockoff aftermarket part.As I found,the motormite brand socket does not fit the cut out in the 93-97 t/a's as advertised.
    Celina, Ohio
    1999 Pontiac Trans Am
    I have the same problem since the day i bought the car back in april 99. i have replaced both pigtails, sockets, and housing, and i dont know probaly over 100 bulbs since the day i got the car. seems too blow one about every other time i drive the car. it did get better after replacing everything couple years ago but still sucks. when you replace the housing put some silicone on the socket when you put it back into the hole. this will help seal the whole and not let water in too blow the light bulb. i love the car but thats the only problem i have really had since i bought it. hope this helps thanks, [email protected]
    Junior Member indig0_2000's Avatar
    Feb 2006
    San Pedro, CA
    pewter
    2001 Trans Am WS6 Conv.
    i keep one in the glove compartment at all times. Mine is the drivers side lamp.
    '01 ws6 vert a4
    Jan 2008
    Everett, WA
    1998 Firebird T/A WS6
    Same problem here, my socket rusted out, put a new bulb in and in a couple weeks its rusted through the bulbs contacts, replace the socket with one that has a thicker gasket, and before you put your new bulb in put some dielectric grease in the socket, should eliminate any moister getting in the socket.
    NeW YoRk
    2001 ws6
    flasher had the same problem changed the flasher problem sovled
    Junior Member FireRescueWS6's Avatar
    Jan 2008
    Columbia, SC
    1999 WS6 Trans Am
    My driver side turn signal is out, I believe its just the bulb. But i found that it is quite difficult to get to... Whats the best way? I can get my hand up though the empty space under the turn signal but I can get the connection loose... Any ideas?
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    Bottom of the car there are two 10mm bolts holding a flap closed. Remove the bolts and you'll have easy access.
    Member transamdude99's Avatar
    East Wenatchee, Washington
    1999 Tran-Am WS7
    hey man i had this same problem and i spent a small fortune replacing bulbs but i just found out the connections were REALLY dirty and gunked up from moisture and stuff. so i bought some basic electrical cleaner at a local parts store and sprayed them, let them sit for a few minutes and then i cleaned them out good with cotton ear swabs. i havent had a problem since
    sunset ws6 Monster-Inside's Avatar
    Franklin County
    Sunset Orange
    Two, 2002 WS6 Trans Ams
    i had the same problem it was just water building up in the socket due to a bad seal
    New Jersey
    2000 Pontiac Trans Am
    If you keep replacing bulbs and they don't blink but light up try checking the relay for the turn signal. All my bulbs worked but flashers were acting weird. Changed that and haven't had problem since.
  1. Question: turn signal keeps going out.
    By dav-02ws6-m6 in forum General Help
    Last Post: 02-02-2012, 03:19 AM
  2. Turn Signal
    By edrvsqz1980 in forum Firebird / WS6
    Last Post: 11-15-2010, 06:58 PM
  3. Help: help with turn signal
    By danmeksch in forum Camaro / SS
    Last Post: 01-19-2010, 03:25 PM
  4. Turn Signal
    By Z28boy2000 in forum Stereo and Electronics
    Last Post: 03-30-2009, 12:36 PM
  5. Turn signal help
    By Blksilvr in forum General Help
    Last Post: 08-08-2007, 05:46 AM
