    Senior Member GottaHaveLS1's Avatar
    Connecticut
    1999 Trans Am M6
    Lowering springs w/ stock shocks?
    I really want a lowered stance for my car, but I don't think i can afford to get both shocks and springs (~$700). How will my car be with just the springs? I've heard it's bad for the stock shocks (which will be replaced someday) but how long with they last and how will my ride be with just springs?
    it's shitty, man. I'm currently running around like that. It's a very harsh ride-every bump is amplified b/c the shocks are compressed so much and can't absorb the bumps properly.
    Seriously, get the springs you want, let them sit in your garage; then get the shocks and install it all at once.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    stock shocks is the culprit of all the handling (or lack of there of) in stock form... if anything, I'd change shocks and not springs.
    Since you want to lower, getting Koni SA front shocks will allow to lower 3/4" due to 2 perch locations on the shock. Getting Bilstein HD in the rear keeps cost down, great shock on stock spring... and do the hose-mod in the rear, lowering the same amount.
    Eugenio_SS
    Mike The Guz's Avatar
    Lawndale, CA
    Artic White
    2002 Camaro SS
    Save your money for the shocks. Install everything in at the same time. You will be happy you did. Save and get the koni's all the way around. My springs sat in the garage for about four to five months before I went with the koni's. Did everything at once and I am glad I did.
    2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
    Member ghettosled's Avatar
    cleveland, ohio
    pewter
    1999 camaro ss #4288
    im part of the backwards bunch. eibach springs and stock shocks. one day when i get the money ill get new shocks, one day...
    Senior Member M-Ten's Avatar
    St. Pete, Florida
    Silver+Black/Black+Silver
    1999 TA M6/03 GSXR 600
    Quote Originally Posted by Eugenio_SS View Post
    ok so the koni SA front shocks lets you lower the car 3/4" in the front, and you have to do the "hose mod" on the bilstein HD in the rear to lower the rear also? what is the hose mod, never heard of it? also is 3/4" too much you think for a daily driver? I want to lower the car but I don't wanna be scraping all over everything either
    Jun 2002
    Montreal, CANADA
    triple-black
    the hose mod in the rear is independant of the shock choice.
    On top of the spring, there is the big rubber hat called spring isolator... you can replace that by heater hose on the top 1st coil, to avoid metal-metal contact.
    that lowers the car by ~3/4"... and it's safe... many ppl use this in SCCA races.
    St. Pete, Florida
    hmm ok, i'm going to look into changing out shocks and maybe lowering the car when i get a few more go fast parts
    Feb 2006
    Ada, OK
    2000 Firehawk
    im running eibach springs and stock shocks on mine. rides really ruff and ive broke two shocks on the back on about 6 months. always the pass side rear.
  1. Question: Lowering Springs and Shocks?
    By kool-aide in forum Suspension and Handling
    Last Post: 03-14-2010, 02:42 PM
  2. lowering springs with stock shocks
    By Mr.Lee in forum Suspension and Handling
    Last Post: 11-08-2009, 11:22 AM
  3. Using 1.5" lowering springs with stock shocks?
    By RaceMyLS1 in forum Suspension and Handling
    Last Post: 03-27-2009, 11:40 AM
  4. Help BMR lowering springs. Which shocks?
    By clint195 in forum Suspension and Handling
    Last Post: 12-06-2007, 07:22 PM
  5. lowering springs w/stock shocks??
    By 2MuchFun in forum Suspension and Handling
    Last Post: 08-13-2007, 08:50 PM
