Thread: Lowering Springs and Shocks?
03-13-2010, 06:48 AM #1Senior Member
- Dec 2006
- Deltona, FL
Sebring Silver Metalic- 2002 Camaro Z28
do you need to buy or match the shocks/struts to the springs?
I am watching a shock/strut and spring set. I want to upgrade my shocks, but don't want to lower the car.
This brought up a question. Are the shocks and struts different for stock height vs. a lower spring?
I have absolutely no idea about shocks and springs. I don't want my car any lower than stock. I have the factory body kit on it. I'm already losing a tiny bit of clearance at the side of the car. I have to drive up on a 2x6 just to get my floor jack under it. Personally I love the stock height. I just can't stand the stock struts and shocks.
thank you
03-13-2010, 08:39 AM #2Life In The Fast Lane..!!
- Jul 2008
- SoCal, SD
Brickyard 400 Trac Car#10- 35th Camaro SS/LE Vert
Yes you can upgrade your shocks without springs and yes they're the same height. Bilstein or Koni's,imo. So no worry's with the stock spring in place you'll be at stock height but with a better ride quality. It's the springs that lower the height, if the kit says lowering spring your gonna set lower after the install.
If you want a little better turn in check out a set of sway bars.Last edited by redracer1; 03-13-2010 at 08:42 AM.
03-13-2010, 01:56 PM #3Senior Member
- Dec 2006
- Deltona, FL
thank you. I wasn't sure about this. I didn't know if there were shocks made specifically for lowering springs or not.
I wonder if any one knows what popular brand of shocks would be blue?
I know the Bilstiens are blue and yellow. I don't know if there is a common color to some brands or not. I know the KYB Gas-a-just are white, and the KYB AGX are red.
thanks for the reply. at least now i know the shocks are not specific to lowering springs, just the car,
03-13-2010, 07:26 PM #4Life In The Fast Lane..!!
- Jul 2008
- SoCal, SD
Tokico's are blue.
03-14-2010, 05:38 AM #5
03-14-2010, 06:04 AM #6Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
If your staying at stock height then you have plenty of options
Heres my list
1st choice Koni
2nd Bilstien
3rd KYB
4th TokicoCraig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
03-14-2010, 06:37 AM #7Senior Member
- Dec 2006
- Deltona, FL
ah thanks. I know the KYB Gas-a-just are not a big improvement. I can say on my 1st z28 they were better than my stock socks.
Maybe I will skip the auction and keep saving for the KYB AGX series. I can't justify dropping the kind of money opt 1 and 2 would be. Even a small improvement over stock at a modest cost is worth it to me. I'm not going out and racing. If i was I would be saving all my pennies for the breakables,
i was just looking at the auction just in case there was something worth my time. i will just move on,
03-14-2010, 08:51 AM #8
03-14-2010, 01:42 PM #9
lowering springs + drag shocks
By bgon99ss in forum Suspension and HandlingReplies: 4Last Post: 05-02-2010, 11:51 AM -
lowering springs with stock shocks
By Mr.Lee in forum Suspension and HandlingReplies: 24Last Post: 11-08-2009, 10:22 AM -
Help BMR lowering springs. Which shocks?
By clint195 in forum Suspension and HandlingReplies: 6Last Post: 12-06-2007, 06:22 PM -
Lowering springs w/ stock shocks?
By GottaHaveLS1 in forum Suspension and HandlingReplies: 8Last Post: 12-05-2007, 09:01 AM -
lowering springs w/stock shocks??
By 2MuchFun in forum Suspension and HandlingReplies: 20Last Post: 08-13-2007, 07:50 PM
