Page 1 of 3 123 LastLast
Results 1 to 20 of 57
    Destroyer of Mustangs RaceMyLS1's Avatar
    Mansfield, OH
    Black/Red
    98 Trans Am/99 Firebird
    Using 1.5" lowering springs with stock shocks?
    I have a 98 TA with 57k miles on it. I am about to have someone install a set of lowering springs on it and I was wondering if I need to have new shocks installed as well.. Any thoughts?
    Military Muscle :usa: MYSCZ06's Avatar
    Columbia,SC
    Millienum Yellow
    2003 Corvette Z06
    plenty have done it on stock shocks but it is highly recommended to swap shocks..strano makes a great set!!
    Shawn
    Daily: 2003 MY Z06 D1SC | Toy: 2006 Hayabusa Garrett T-3 | Hauler: 2007 Nissan Titan LE CC
    I like being Blown!!
    Mansfield, OH
    Black/Red
    So I should replace the front and rear shocks? Ok. What about an adjustable panhard bar? Do I need that? Everyone says you absolutely need it if you lower an fbody..
    "A blind chimpanzee driving a WS6 with a dead hooker strapped to the hood should be able to put that thing deep into the 13's."
    Columbia,SC
    Millienum Yellow
    2003 Corvette Z06
    I swapped all my shocks and springs for best handling and ride..I also added a adj pan hard in the event you need to adjust the rear once you lower it... I didnt have to adjust mine.
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Do it all at once, it will save you the hassle of doing the fronts twice when you get new shocks.
    For lowewring springs Koni's would be my first choice then billstiens.
    And an adj panhard bar is a must.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Member side2000's Avatar
    md
    2000 camaro ss
    you can use stock shocks but they are beat. koni adjustables all the way around. . . .they are expensive but you get what ya pay for
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    shocks are a must... stock one suck.
    By lowering, the rates are most certainely higher, making the stock shocks even worse on that situation... so you'd want shocks regardless.
    Eugenio_SS
    Quote Originally Posted by RaceMyLS1 View Post
    shout out to a fellow Ohio'n. I've been through mansfield a few times enroute to the in'laws.
    that said-don't trust everything you're told by internet posts, etc. Talk to suspension specialists like Sam Strano (how about he doesn't even sponsor here, but we all just know lol).
    Quote Originally Posted by Pewter_LS1 View Post
    I find this hard to believe.
    md
    2000 camaro ss
    you can trust my posts
    2000 red ss: >2" drop, koni adjustables 'n 275 s-compounds all way around, giant brakes, dynatech LT's, borla catback (no plate), t56, tubular everything, HARD TOP, caged, "stock" heads 'n a mean cam. -2* front camber.
    md
    2000 camaro ss
    just 'cuz he "didnt have to adjust it" doesn't mean it's in the right place. although most lowering kits require panhard adjustments, strange enough as it may be, some cars just seem to keep the rear in place. i really dunno why, it must be variance in position of the panhard body mount from factory, 'cuz i've seen more than one car with perfect geometry after lowering.
    `98 Formula M6 HdTp
    Quote Originally Posted by side2000 View Post
    If it's perfect after lowering with the stock PHB my guess would be the bar is bent.
    I have yet to see even a stock height car with the rear centered properly.
    md
    2000 camaro ss
    so if it's not centered properly from factory, it might just fall into place after lowering.
    i'm certainly not saying i would avoid putting an adjustable panhard rod on my car. no matter what, i'd put one on any f-body i owned, and check geometry/adjust accordingly. in fact, i check/adjust between every race.
    `98 Formula M6 HdTp
    Impossible considering the bars need to be shortened after the car is lowered.
    Actually the Watts link is a better setup anyway.
    md
    2000 camaro ss
    if the rear isn't aligned from factory, either raising the car or lowering the car is gonna put it in place. . .but i wasn't originally saying that for debate sake. it was more a joke than anything else. i was stating my experience with suspension setups, to be heeded however by whoever.
    `98 Formula M6 HdTp
    Sorry man I'm not here to argue with anyone.
    Most of the Factory F-bodies I have seen have the rears biased towards the Left side. And to properly center them the bars need to be shortened. When I added my staggered wheels I ended up getting an adj PHB even though I was on stock springs.
    Junior Member Octavain's Avatar
    Aug 2008
    NW, Arkansas
    1998 Camaro
    What about non-adjustable rear panhand bars? You can look at signature for mods.
    -Aaron
    Mods: SLP Flowpac Cold Air Induction Package, 160 Thermo, TB bypass, SLP (Clutch, Pressure Plate, Flywhell), Skip Shift Elminator, UMI (SFC, Tower Brace, LCA, Torque Arm, Panhand Bar), no cats, Moser 9" w/ 3.89 gears, 5.0 short throw, Strano Springs, Koni single adj, '94 OEM ZR-1 wheels
    md
    2000 camaro ss
    here's a good way to put it: because of the delicacy of the rear axle position (by design of the components that hold axle in place) it is crucial to constantly check the geometry and adjust accordingly. that means you will have to adjust it constantly due to stress, change in ride height, bushing wear, or you may get away with seldom adjustment/one-time adjustment, or never adjusting it at all.
    Mansfield, OH
    Black/Red
    Ok, so in addition to my lowering springs, I have an adjustable panhard bar and a set of front & rear shocks on the way. How do people adjust the panhard bar? Just like by using their eye or a tape measure, or what? I'm planning to have a shop install all of this, since I really don't trust myself. Or if anyone in my area wants to make some quick $$ + pizza + beer, let me know, haha..
    md
    2000 camaro ss
    if you were around me i'd do it for bud light. it's not hard and it comes with instructions. you are gonna pay a shop through your johnson to get it done. yep, to adjust panhard bar you can start by eyin' up the rear on both sides @ fender, then gettin in there with a wrench to adjust. that's usually good enough, but a tape measure is only way to get it 100% perfect in your driveway. need to make sure car is oncompletely flat surface.
    By the way, which panhard rod did you get? some panhard rods can't be adjusted on the car, which kinda defeats the purpose of having adjustability.
  1. Question: Lowering Springs and Shocks?
    By kool-aide in forum Suspension and Handling
    Last Post: 03-14-2010, 01:42 PM
  2. lowering springs with stock shocks
    By Mr.Lee in forum Suspension and Handling
    Last Post: 11-08-2009, 10:22 AM
  3. Lowering springs w/ stock shocks?
    By GottaHaveLS1 in forum Suspension and Handling
    Last Post: 12-05-2007, 09:01 AM
  4. lowering springs w/stock shocks??
    By 2MuchFun in forum Suspension and Handling
    Last Post: 08-13-2007, 07:50 PM
  5. 4 lowering springs 1.7" to 2" drop +shocks all 4
    By boyd in forum Parts Wanted / Trade
    Last Post: 03-15-2006, 12:49 PM
