    olathe ks
    1993 Trans Am
    Did Anyone Run Into Problems Putting In Cam, Im Getting Ready To
    Let Me Know If You Ran Into Problems Putting Cam In So I Now What To Watch For, Thanks
    nope, just follow the write up at ls1howto.com and you'll be fine. I did my swap by myself. It'd be easier with a helper especially when it comes time to move the a/c condensor up and out of the way but a few bungie cords and a little redneck engineering and it can be done with just 1 person. I hope you're doing all the supporting stuff at the same time such as springs, pushrods, oil pump, and timing chain.
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    Just watch for the o ring on the oil pump. I didn't pay as much attention to it as I should and had to pull it back off to replace it. I had all the AC vacuum, guages, oil etc so I just yanked my condenser out of the way. But other than those everything is fairly easy. Did mine at 145K and the lifter cups held the lifters no problem either. I cussed doing the valvesprings more than I did the actual cam. Thats a PITA.
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    All I can tell you is watch the lifters. My motor had about 90K and the lifters didn't hold themselves up. I even had magnets on the lifters and one still fell as the cam was going through the last cam bearing. A lot of trouble if you drop one.
    olathe ks
    1993 Trans Am
    im taking the heads off befor i put the cam in will that make it less of a pain.
    Member Sunset T/A's Avatar
    Spring, TX
    Sunset Orange
    2002 TransAm
    Should be no problem with the heads off, but you really don't need to take them off. Make sure to suck all of the coolant out of the head bolt holes in the block before installing the heads so you don't crack the block when torquing them down. As above, make sure the oring stays straight in the oil pump when bolting up the pickup tube.
    2002 Sunset Orange TransAm 6 spd.
    http://www.mustangmods.com/data/1327/dadsigpic2.jpg
  1. Question: Putting a cam in my car need to know
    By breathnitrous in forum Computer & Tuning
    Last Post: 04-24-2010, 06:09 PM
  2. Putting them to bed.
    By pajeff02 in forum General Help
    Last Post: 11-19-2009, 07:38 PM
  3. Putting together my 408
    By lancesT/A in forum General Help
    Last Post: 08-07-2009, 11:26 AM
  4. DID ANYONE RUN INTO PROBLEMS PUTTING CAM IN lt1
    By fast93ta in forum Firebird / WS6
    Last Post: 11-24-2007, 04:26 PM
  5. putting the car away
    By 98redbird in forum General Help
    Last Post: 11-18-2005, 03:31 PM
