    1998 Pontiac Trans Am
    putting the car away
    alright, im putting my 98 T/A away for the winter, what all should i do to get her ready?? what do you guys do?
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    well, I'm in cali but my bird has seen storage in the winter time cause of rain and repairs. But generally these are my procedures.
    1. Park on strips of carpet to make sure your tires will be ok
    2. Top of your tank to prevent condensation and fill with stabil.
    3. Change your oil to fresh oil.
    4. Change your coolant out to fresh coolant. Make sure you use distilled water and fresh dexcool.
    5. crack your windows
    6. Remove your battery and place on a trickle charger for the winter.
    7. Wash and put a fresh coat of wax to keep the paint protected and fresh
    8. Place under a car cover
    I know I may be forgetting something but those are the basics for storage.
    may i ask why you crack your windows, and i changed my oil about 1500 miles ago with mobil 1, and i flushed my coolant system about 3 or 4 months ago, so they should be alright for the winter, right??
    I Fixed Da Rear jimbo98z's Avatar
    Raleigh, NC
    Mystic Teal
    1998 Z28 M6
    i've always heard crack the windows just so it doesnt get stale smelling in the interior.
    also, i would think the windows could stick to the seals after sitting up against them for so long, making them possibly tear when you roll the window down for that first summer drive.
    Junior Member teal monster's Avatar
    deptford NJ
    teal
    1998 z28
    dont forget the battery tender also.
    Member TROYWS6X's Avatar
    New York
    1998 WS6
    I always put a little extra air in the tires if it's not on jack stands. Helps reduce flat spots in the spring.
    quicky06
    Guest
    what i would do ischange the oil. go out and get a grease gun if you dont have one or take it to a shp and lub ub everything. get something to block of the tail pipes. put some vianl conditioner on the dash and all other interior parts(if you have leather use leather conditioner) clean the car and put a good coat of wax on it i would use some nu finish for storage. then go get a winterizer fuel treat ment like stabil and run about a half tank through your car. put it up on jackstands and take off the tires and deflate them to around 10 psi. and get an expensive car cover. oh and get some rubber/ vinal treatment and put it on ALL of your seals around the doors, rear hatch, and t-tops. and if its going to be in a garage with a heater take off the t tops, crack the windows and maybe the doors so its not so bad on the seals.
    just what i would do
  1. putting in a 4l60e
    By suede in forum Automatic Transmission
    Last Post: 04-28-2010, 06:36 AM
  2. Question: Putting a cam in my car need to know
    By breathnitrous in forum Computer & Tuning
    Last Post: 04-24-2010, 06:09 PM
  3. Putting them to bed.
    By pajeff02 in forum General Help
    Last Post: 11-19-2009, 07:38 PM
  4. Putting together my 408
    By lancesT/A in forum General Help
    Last Post: 08-07-2009, 11:26 AM
  5. DID ANYONE RUN INTO PROBLEMS PUTTING CAM IN lt1
    By fast93ta in forum Firebird / WS6
    Last Post: 11-24-2007, 04:26 PM
