Results 1 to 11 of 11
Thread: Cam Decision?
11-22-2007, 08:06 AM #1
Cam Decision?
My step-dad is telling me not to put a cam in my car for it will ruin the drivability and longevity of the engine im not planning on going with a real big cam just want somthing that i can smoke the other guys on the street. the one im looking at is a Texas Speed Torquer v.2 Camshaft. i read all the other forums and i wanted to know if anyone has installed a cam without the ticking noise. that just doesnt sit right in my head. and the only thing i can figure is that it could be the heads not being built up right. or too big of a lift with not enough spring. i plan on porting and polishing the heads and putting a new valve train in them. along with the stiffer rods. anyone with any knowledge on this would be greatly appreciated.
happy thanksgiving
Wes
11-22-2007, 11:15 AM #2
Bigger cam and it'll tick some. Just the valves opening and slamming shut. Mine does. It will kill your gas milaege some.
11-22-2007, 11:29 AM #3
mine didn't tick that is untill I broke a piston
11-22-2007, 01:43 PM #4
ok so i guess my question is how big can you go with the cam before it starts to tick. heres the stats with the one i want to go with. Texas Speed Torquer v.2 Camshaft
TSP XS Series Camshaft: 232/234, .595"/.598" with 112 LSA
11-22-2007, 04:36 PM #5
mine is a comp cams 234/238 duration 595/605 lift 114 lobe seperation the only "tick" I know of with an ls1 was the early ones and the wristpins ls1's have floating pins also the aluminum block lets more internal noise out than an iron block my suggestion to you is build a motor for your car while you can drive it then you can swap it out and sell the stocker for a decent amount
11-23-2007, 05:32 AM #6
11-23-2007, 06:18 AM #7
11-23-2007, 07:56 AM #8
somone told me that putting a cam in these engines greatly depreciates the longevity of the engine is this completly true i know it could be to an extent but i really dont think it would be suggnificant if you took the right precautions
11-23-2007, 08:18 AM #9
these engines are pretty durable. It's more of how you drive it and take care of it that determines it's longevity. I wouldn't spin the motor real high and stay on top of the maintenance and you should be fine. I also would look more at a 224 or 228 cam. The tune is also very important as far as how it drives so I would have a plan for who/where I was going have tune it.
11-23-2007, 10:25 AM #10
11-26-2007, 12:24 PM #11
Big decision
By bluehawk2000 in forum NitrousReplies: 1Last Post: 01-17-2010, 02:23 PM -
ls6 cam bad decision?
By mach350z in forum Internal EngineReplies: 11Last Post: 06-30-2007, 09:08 PM -
help with LSA decision
By chad2775 in forum Internal EngineReplies: 5Last Post: 06-20-2006, 09:48 AM -
MAF decision
By bandit95 in forum LT1Replies: 6Last Post: 11-03-2005, 05:40 AM
