Results 1 to 2 of 2
Thread: Big decision
01-15-2010, 11:36 AM #1
Big decision
Ok I will go ahead and give the parts I will be putting on the car first
trick flow 215cc heads
tourquer v2 cam at a 112 lsa
92/92 nick williams tb and fast intake
yella terror rockers
chromely push rods
and running 11:1 compression
I Just started thinking about getting a nitrous set up most likely a wet or direct inport. Now I know I will have to run colder plugs such as the t6's will that affect my powerband much than running a hotter plug that I would without. I am looking at spraying a 100 to 125 shot possibly. Is their anything else I would have to look at doing to my car so it is the best possible set up and how much am I looking at spending? I am basically saving the nitrous for the bigger boys such as maybe running into a z06 or if I am really lucky a big boy cobra cause I know their out their, or maybe catching that lambo that runs around where I live.
01-17-2010, 02:23 PM #2
It the plugs should not effect the powerband of your car.
There really isnt anything else you need other the the kit and all the safety features if you choose to get them.
Timing control and colder plugs is probably the only "have to get" items to make it work.
Cam Decision?
By bigbucks39 in forum Internal EngineReplies: 10Last Post: 11-26-2007, 12:24 PM -
ls6 cam bad decision?
By mach350z in forum Internal EngineReplies: 11Last Post: 06-30-2007, 09:08 PM -
help with LSA decision
By chad2775 in forum Internal EngineReplies: 5Last Post: 06-20-2006, 09:48 AM -
MAF decision
By bandit95 in forum LT1Replies: 6Last Post: 11-03-2005, 05:40 AM
