Thread: help with LSA decision
06-18-2006, 01:24 PM #1Junior Member
- Dec 2005
- GA
black- 2000 WS6
I am getting a TR 224/224 and need some advice on LSA, there are no tuning shops close to me so I am going to have to get a mail order tune for now, will a LSA of 112 be okay with my daily driver with a mail order or do I need to get it on a 114??? Thanks for your advice!
06-19-2006, 03:40 AM #2Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
is the car an a4 or m6? if auto, then go with the 114. You'll have better vaccum than the 112. If a stick, a 112 shouldnt be bad at all.
06-19-2006, 06:22 AM #3member since may 2000
- Dec 2002
- n/w chicago
a few bolt ons, 379 rwhp
11.96 @113.25
06-19-2006, 01:19 PM #4Junior Member
- Feb 2006
- Charlotte, NC
NBM- 2002 Z28
It also depends on how you like the sound.
Speaking for myself (personal opinion): anything less than 114 LSA sounds like it's about to stumble and die. In fact, most of the cams with 114 sound like they're about to stumble and die. They don't, I know, but for me, that's just what it sounds like. For some people, that's what they want, since the sound also harkens back to the muscle cars of the 60's and 70's. For me, it just isn't what a modern car should sound like.
(P.S. - Not trying to start anything, it's just an opinion of the sound.)
06-20-2006, 02:34 AM #5Senior Member
- Aug 2003
- Honolulu HI
to rebuttle that comment, Id like to state, that there are more factors to lope than what you are refering. Overlap is one big one. Generally your overlap at .050 will tell you how much a cam has. The more overlap, the more reversion, more lope
Also, the tune and idle speed come into play. I have had a 228/228 114 and a 230/232 112 cam. Both of which idled fine. The one on the 112 idles just as good as the 114. My idle speed is set to 975 right now, should I drop it to say...850, then Ill obtain the sound you are refering to. Just wanted to clear things up a bit.
Nino
06-20-2006, 09:48 AM #6member since may 2000
- Dec 2002
- n/w chicago
my car has a 114 las and doesnt sound like its gonna die out.
Originally Posted by Aegnor
while lsa has alot to do with lope, if you have idle set to low even on a 115 lsa its going to sound like its gonna stumble and die.
you can tell im cammed but you more or less have to be into cars.
my cars idle is about 775 rpm.
Big decision
By bluehawk2000 in forum NitrousReplies: 1Last Post: 01-17-2010, 02:23 PM -
Cam Decision?
By bigbucks39 in forum Internal EngineReplies: 10Last Post: 11-26-2007, 12:24 PM -
ls6 cam bad decision?
By mach350z in forum Internal EngineReplies: 11Last Post: 06-30-2007, 09:08 PM -
MAF decision
By bandit95 in forum LT1Replies: 6Last Post: 11-03-2005, 05:40 AM
