    Super Fast Nosws6's Avatar
    ATX
    2001 Trans Am Ws6
    Whining sound when clutch is depressed
    Every time I have the clutch in I hear a sort of whine. Anyone have any thoughts as to what this may be or how I should go about fixing it? Is it something as simple as flushing the fluid?
    Senior Member JonB's Avatar
    Florida
    2005 GTO
    Sounds like a worn throw-out bearing.
    Throw-out bearing Maintenance Tips/Suggestions: The classic symptom of a worn throw-out bearing is a whirring or growling sound when applying the clutch pedal, which goes away when releasing the pedal. Premature wear of the throw-out bearing can occur when there is insufficient clutch play, resulting in a throw-out bearing that spins continuously. If the bearing fails, it may seize and quickly wear the fingers of the pressure plate. The throw-out bearing does not require routine maintenance, but should be replaced when clutch replacement becomes necessary. Consult a professional technician to determine whether the throw-out bearing or other parts of the clutch assembly need replacement.
    05 PBM GTO
    Cold Air Inductions CAI,
    Relocated IAT with omega,
    Slp Predator tune,
    Flowmaster axle back with H pipe,
    Custom tuned TCM.
    BC Racing coil overs
    Sold 01 z28
    ATX
    2001 Trans Am Ws6
    Thanks man, that definitely helps.
    Member Orange99z28's Avatar
    joliet il
    orange
    99 z28
    same problem here, i'm hopin it holds until spring. is there any way i can definitively find out if its the t/o bearing without tearing it apart?
    same sysmptoms, clutch still works great (aside from pos gm engineers making a clutch that slipped even stock lol) every time i push clutch it whines and or sounds like theres some kind of grinding (like rubbing 2 pieces of steel together) sometimes when cold it also makes a high pitched whine that goes away when i push the pedal even slightly.
    any tips/advice? thanks
    Wilmington, NC
    '95 droptop TA
    ^^ same issue here with my '95 t/a. new carquest slave & master cyl, new stock clutch kit, fully bled - however, on top of that
    it's like there's resistance when i push the clutch pedal in at speed, while in gear. Only does this at speed. if i'm at a light, in a gear, and push the clutch in - no 'grind/rub', whatever.
    any ideas?
  1. Whining sound
    By Promise517 in forum Firebird / WS6
    Last Post: 04-06-2011, 02:12 PM
  2. What is this whining sound?
    By BdAsBrd01 in forum General Help
    Last Post: 06-02-2009, 04:40 PM
  3. Question: Whining sound
    By Diesel235 in forum General Help
    Last Post: 04-01-2009, 05:09 PM
  4. Question: Whining sound from speakers?
    By dpeach in forum General Help
    Last Post: 08-05-2008, 09:27 AM
  5. high pitch whining sound
    By kkkaz13 in forum Drivetrain
    Last Post: 06-12-2007, 10:43 AM
