Thread: Whining sound
    Member Promise517's Avatar
    Atlanta, GA
    2001 WS6
    Whining sound
    Hey I love these cars but my profession is computers....that said is this sound something I should be worried about? All fluids checked out and running Synthetic oil. The sound started after a 350 mile drive (not hard) and the last part of the drive I went through a pretty heavy puddle of water (however the video was taken the morning after.
    Any thoughts?
    Thanks Fam
    [ame]http://www.youtube.com/watch?v=wg0qs5pE328[/ame]
    Member godless-phoenix's Avatar
    culver city, Ca.
    Blackened fire chicken
    2000 Pontiac Trans Am WS6
    i wouldnt be too worried if it hasnt affected the performance of the car...maybe itll go away after the car has dried off a little more??? sort of sounds like a pulley, power steering pump whining maybe, or sumthing like that... i dunno its hard to say
    sounds to me like your power steering pump... check the fluid level and see how full it is... it's probably a bit low...
    Atlanta, GA
    2001 WS6
    Thanks you two, paranoid about my car.
    Sent from my Nexus One using Tapatalk
    Pittsburgh
    2008 Hummer H3
    Prolly drowned the Alt. with water.. Imho
    Or possibly water was forced under the PS cap..
    Check the PS fluid for water/foam when the engine is running..
    If it is the PS pump the sound will likey get louder when the filler cap is removed..
    Also IF water did get into the PS pump it will soon die...
    culver city, Ca.
    Quote Originally Posted by Promise517 View Post
    im sup[er paranoid too! haha...
    Senior Member Lunatikgixxer's Avatar
    Mar 2010
    St Pete, FL
    Bat mobile black
    2000 Trans am WS6 M6
    its sounds exactly like my power steering pump when it was going bad, mine would whine at idle also so yours isnt too bad. It might be low, it might be full but the fluid might be bad, if its black then its bad. Id change it, DONT WAIT either. Thats what i did and it ended up ruining my PS pump and i had to change the whole thing. If you decide to change the fluid put a towel or heavy rag over your alt so no fluid gets on it, if it does then youll be replacing that too!
  1. What is this whining sound?
    By BdAsBrd01 in forum General Help
    Last Post: 06-02-2009, 04:40 PM
  2. Question: Whining sound
    By Diesel235 in forum General Help
    Last Post: 04-01-2009, 05:09 PM
  3. Question: Whining sound from speakers?
    By dpeach in forum General Help
    Last Post: 08-05-2008, 09:27 AM
  4. Whining sound coming from engine....
    By LgndKller20073 in forum General Help
    Last Post: 01-16-2008, 11:05 AM
  5. Whining sound when clutch is depressed
    By Nosws6 in forum Manual Transmission
    Last Post: 12-09-2007, 05:55 AM
