Results 1 to 15 of 15
Thread: What is this whining sound?
06-01-2009, 03:30 PM #1
Today my car started making this whining sound when I turn the steering wheel. It's shifting fine (auto) and everything else seems to be alright. The steering wheel was a little hard to turn at the time. Any ideas what this sound could be?
06-01-2009, 03:39 PM #2Just a farmboy
- Jun 2007
- Montpelier, VA
Pewter- 2000 Pontiac Trans Am
air in the power steering fluid. mine does it if i jerk the wheel around or take turns hard. usualy you just change the fluid and it will go away.
06-01-2009, 04:52 PM #3Custom Painter/Tech
- May 2009
- Plainwell, Mi
Flame Red / Orange Custom- 1998 Trans Am
Yeah I agree with V8MUSCLE it is your power steering pump you can try changing the fluid it could have air or moisture in it and both compress a lot more than power steering fluid so your pump dose not work properly, however if that dose not fix it you will have to change the power steering pump luckily its not really too hard to change but the new pump dose not come with a pulley so you have to remove it and put it on the new pump hopefully it all works out for you.
06-01-2009, 06:27 PM #4
"Yeah I agree with V8MUSCLE it is your power steering pump you can try changing the fluid it could have air or moisture in it and both compress a lot more than power steering fluid so your pump dose not work properly, however if that dose not fix it you will have to change the power steering pump luckily its not really too hard to change but the new pump dose not come with a pulley so you have to remove it and put it on the new pump hopefully it all works out for you."
Thanks for the heads up, could it still be the power steering pump if it makes that sound while driving? I mean,I could still hear it a little when in drive. Any idea how much a new pump would be? Thanks again!
06-01-2009, 06:37 PM #5Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
Yes, should also get way worse when the wheels are cut hard to one side or the other....
06-01-2009, 06:39 PM #6
06-01-2009, 07:31 PM #7
06-01-2009, 07:33 PM #8
06-01-2009, 08:09 PM #9Bone it like you own it
- Sep 2005
- TEXAS... U mad?
No high RPM's for you......
I have twisted shafts in 4 pumps doing burnouts at high RPM's, Insta-no-power-steering...
06-01-2009, 08:21 PM #10
my power steering is "heavier" in the camaro than most other cars I drive.
is it just the nature of the massive front tires?
it def has power steering, just a little harder to turn than sayyy my buick century
06-01-2009, 08:37 PM #11Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Nut Butter!!!
My 4x4 tahoe is real soft and crisp, but yes the f-body is "heavier" if you will.
06-02-2009, 01:09 AM #12
06-02-2009, 01:11 AM #13Impounded
- Oct 2007
- Beaver Dam KY
06-02-2009, 02:00 PM #14Member
- Nov 2008
- harrisburg pa.
black- 02 vette vert
06-02-2009, 04:40 PM #15Custom Painter/Tech
- May 2009
- Plainwell, Mi
Hear is a link to a pump i found from Advance Auto Parts its $54.99 plus $30.00 for the core charge ---->http://shop.advanceautoparts.com/web...ring%20pump___ and if your pump is doing that while you are driving straight then you should change it as quickly as possible. Good Luck!
Whining sound
By Promise517 in forum Firebird / WS6Replies: 6Last Post: 04-06-2011, 02:12 PM -
Question: Whining sound
By Diesel235 in forum General HelpReplies: 6Last Post: 04-01-2009, 05:09 PM -
Question: Whining sound from speakers?
By dpeach in forum General HelpReplies: 4Last Post: 08-05-2008, 09:27 AM -
Whining sound coming from engine....
By LgndKller20073 in forum General HelpReplies: 8Last Post: 01-16-2008, 11:05 AM -
Whining sound when clutch is depressed
By Nosws6 in forum Manual TransmissionReplies: 4Last Post: 12-09-2007, 05:55 AM
