    Junior Member Bluebayou's Avatar
    Raleigh, NC
    Blue
    2002 WS6 Trans Am
    New owner....headlight woes
    Recently picked up a 2002 WS6. Get in it tonight and the headlights pop up, but the passenger light isn't working; neither the low beams or the highbeams. Any ideas on the problem? I searched the threads and seems like most people have issues with the gears or motors. Is there a switch in the housing that turns the lights on when they flip up or do the lights come on automatically and then flip? I am thinking since neither the highs or lows work, it is a connection gone bad somewhere. Please help!!
    Junior Member Redstaff's Avatar
    Vancouver B.C. Canada
    2001 Trans Am WS6
    the switch
    Quote Originally Posted by Bluebayou View Post
    You have to pull the dash-headlight knob off, pull the dash off( it just pops off when you pull it toward you) then remove and replace the switch. I would look for short or bad connection first though. Good luck!
    Senior Member GULLETT17's Avatar
    Muncie, IN
    00 TA PWTR, 98 VertTA NBM
    80 TA BLK, 80 Formula NBM
    my bird did that every once and a while and its a bad connection at the headlight harness. i just cleaned the connections and it was fine.
    2000 TA, A4, LS6 intake, Magnaflow, WS9 hood, BMR STB, UMI boxed SFC, Spohn LCA, 9" Ford
    1998 TA Vert,​ NBM, M6, Flowmaster, WS6 hood, WS6 airbox, C6 wheels, UMI SFC, BMR STB
    1998 Bird, Black, V6, A4, 18" 077's, Wings West Body Kit
    1980 Formula, NBM, 402BB, cam, DR timing, LT headers, 3" TD w/ flowmasters, TH350
    1980 TA, Black, 301, bone stock
    Moving forward. Pyromaniacal's Avatar
    Utah
    Blue/Yellow/White
    95 T/A 383
    Check your headlight connection, if you pull off the front plastic shield you should be able to reach in and check to see if it has fallen out, which did happen to me once. Otherwise, you can probably pull it out just far enough to see if anything has gone awry w/ the connector.
    Raleigh, NC
    Blue
    2002 WS6 Trans Am
    Thanks for the advice. I managed to pull the connectors off tonight and the prongs on the light itself did look a little corroded. The harness connectors seemed to be a little on the corroded side too. Can you purchase the harness connector at a local parts store or would it be better to just cut off the wire connector and use two female wire connectors to hook it back up?
    Happily Married
    Moundville, AL
    2002 WS6
    dumb question but it could be the bulbs? if you just bought it? were they working b4 and not now?
    Raleigh, NC
    Blue
    2002 WS6 Trans Am
    Come to find out, it was the bulbs. Finally some time tonight at a friends garage to look into it more closely. Thought thats what it was, but both the high and the low beams going out at the same time made me think it may be more. The high beam may have been out for a while, the connector looked like it had gotten a little hot. Most of my driving is in the city so I wouldn't have noticed the high beam being out at first. Thanks for all the help though!
    Muncie, IN
    glad you figured it out . . bet you can see a hell of a lot better now!
    Happily Married
    Moundville, AL
    2002 WS6
    no prob. i didnt want to insult your intelligence or nothing just wanted to throw that out there! but good thing you got it fixed
  1. Headlight woes!!
    By jayroca in forum Firebird / WS6
    Last Post: 04-03-2016, 05:03 PM
  2. Headlight motor woes..
    By SouthernBornThriller in forum Firebird / WS6
    Last Post: 07-23-2009, 05:10 PM
  3. Previous Owner Woes AKA how to clean a MAF?
    By Wheels in forum External Engine
    Last Post: 05-01-2008, 11:01 AM
  4. Help: TA woes.
    By SStriker in forum General Help
    Last Post: 04-19-2008, 08:04 PM
  5. headlight woes
    By '00T/A in forum Firebird / WS6
    Last Post: 09-03-2007, 08:17 PM
