Thread: TA woes.
    LoudMouth SStriker's Avatar
    Westminster/Sykesville, Maryland
    2000 Trans Am
    Unhappy TA woes.
    Ok so a few months ago my car randomly thumped hard and then made a horrid whine. I limped it home and pulled it apart. the flex plate was rubbing the oil pan. I got a job and saved up. Finally put in a TCI flex plate with ARP bolts. Now i figured this has to fix it. It Made it about a 1/4 mile down the fucking road and it did it again. Now i changed my oil aswell and found a peice of metal about the size of a pencil tip on the drain plug magnet. I was sketched out about it but said fuck it. Now im lost. If it was a bearing it should be knocking i thought. Now i dont know what to fucking do. Ive been without my car for months and had to barrow my dads truck. it SUCKS.
    Mods:
    160 thermo
    P&P throttle body
    Diablo Tuner
    EGR!
    AIR!
    Gutted Cats
    Loud Mouth
    Lid
    PerformaBuilt Stage 2
    TCI 3500
    B&M Tranny Cooler
    Custom Cold Air
    TCI Flex Plate
    Poly Motor Mounts
    Poly Trans Mount
    Poly Torque Arm Mount
    Custom Catch Can
    Also my rear Main seal started to leak after it happened. i dont know if its related but im sure it is.
    Suggestions on what my problem is?
    Torque Addict!
    Feb 2006
    2002 WS6
    hmm. for the flex plate to be rubbing the oil pan sounds like the crank is walking forward. Which would very well mean a rebuild and new crank. How every I know very little about these motors, internally anyways.
    The small piece of metal may be a needle bearing from the rockers, seem they are known for spitting them out from time to time.
    2000 Trans Am
    Tranny or Engine
    what does everyone think?
    Member imflyn's Avatar
    Indy
    '07 Silverado
    Was the old flex plate cracked?
    2000 Trans Am
    No. but the one hole looked a bit oblong.
    i ordered the new one thinking the old one was cracked.
    Didnt yank the tranny first cause im always working./
    2000 Trans Am
    valve body was gunked causing stall to ballon
    fixed
  1. DRL Woes!
    By wileyCoyote in forum Stereo and Electronics
    Last Post: 10-10-2011, 03:32 PM
  2. clutch woes
    By V8MUSCLE in forum Manual Transmission
    Last Post: 09-27-2009, 03:02 PM
  3. Help: Transmission woes
    By Ramairgod84 in forum Manual Transmission
    Last Post: 06-20-2009, 03:53 PM
  4. z28 computer woes
    By prophotog in forum Computer & Tuning
    Last Post: 03-21-2009, 01:38 PM
  5. M6 Woes
    By wooddaniel in forum Firebird / WS6
    Last Post: 12-27-2006, 04:04 AM
