    North America
    1999 Trans-Am
    Previous Owner Woes AKA how to clean a MAF?
    Ok so it's not really that big a woe, nor can I say for SURE that it was the previous owner but somewhere along the line when somebody was working on my car they pried the lid up off the airfilter and pulled the bellows out of the collar on the lid, so the car ran for who knows HOW long with essentially no filtration. I know this you see, because the MAF screen had a TON of crap in it, but the filter was pretty much spotless.
    So I took it apart and took a vacume to the screen and got it cleaned up fairly well, and then gingerly used the vacum on the other side as well, careful not to damage the sensors, but I know I've read before about using some kind of solvents on them and before I go spraying anything in there I wanted to check sith you folks and see the proper way to clean these things without damaging them.
    Member 346ci's Avatar
    AK
    1998 Z-28
    NAPA carries an aerosol MAF cleaner, works pretty well and will not damage the sensor
    Member squee's Avatar
    Baton Rouge
    2000 SS M6
    I'd just use some CRC contact cleaner. Its made for electrical things, and shouldn't damage it.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Check your local parts store for "CRC Maf cleaner".. Run ya about 4 bucks but will do the trick.
    J
    i used rubbing alcohol and a q-tip to clean the little sensors... workes fine for me... just got to be very carefull and have a steady hand...
    NW Chitown
    2002 WS6
    Quote Originally Posted by sunsetorangess View Post
    J
    +1
  1. Replies: 2
    Last Post: 04-24-2015, 05:36 PM
  2. Previous Owner Cut Up the Intake...
    By Naaman in forum External Engine
    Last Post: 01-11-2012, 06:04 PM
  3. Looking for previous owner of my bird.
    By Nero.Jacinth in forum Rocky Mountain Members
    Last Post: 06-28-2007, 01:32 PM
  4. Searching For Previous Owner
    By XKALIBER in forum Firebird / WS6
    Last Post: 02-22-2007, 03:08 PM
  5. Previous Owner Ranters Inside
    By Mr. CarelessAndImprudent in forum Almost Anything Goes
    Last Post: 04-17-2006, 05:17 PM
