Thread: 99 Firehawk widest tire
10-17-2007, 12:15 PM #1
What is the widest tire that will fit on stock 99 Firehawk rims? I need to purchase two tires and wondering if I can go wider for the rear. stock size 275/40/17
10-17-2007, 12:26 PM #2
- Oct 2006
- St. Clair Shores. Michigan
285/40/17's will work
I've seen 295 and 315's mounted on stock 9" wheels before but I wouldn't recommend it.
10-17-2007, 07:37 PM #3
if you put on anything bigger than a 285 your gonna have to cut off the rubber stops behind the rear wheels.their only purpose is to help the car from bottoming out.and on the front 275 is the widest you can go w/out rubbing. but if you do cut the rubber stops you can go all the way up to a 315
10-21-2007, 02:17 AM #4
- Jun 2007
- corona ca
white, white and pewter- Rip99SSA4,74Z28M4,02SSM6
huh, i have 295;s on and i had to cut nothing but this may be cause its on a 18 inch wheel
10-22-2007, 05:01 PM #5
look on the inside edge of your rear tires and tell me if it looks like something has been wearing it down, if not someone may have already done it before you. the tires will still fit and go on but they will ride the rubber stops. check it out and let me know.
10-22-2007, 05:04 PM #6
- Thornton, CO
I have 315/35/17's on the rear without any rubbing at all. But that is on an 17x11" wheel.
I personally wouldn't run anything wider than a 275 on those stock wheels. Anything bigger and you will start to loose contact patch because of how the tire sits on the wheel.2008 Trailblazer SS
Lowered, HID's, tinted.
10-24-2007, 03:47 PM #7
10-24-2007, 03:51 PM #8
- Jun 2007
- corona ca
its cool man happens to the best of us, the only problem i had on mine which are 10.5 wide is there is a little part of the inner fender that pokes out just a little bit, i just take a hammer and give it a few good ones and repaint over,
What is the widest tire I can run?
By INeedLS1 in forum Wheels and TiresReplies: 6Last Post: 12-21-2009, 06:11 PM -
widest tire
By Nitro_Junkie97 in forum Almost Anything GoesReplies: 22Last Post: 04-03-2008, 03:15 PM -
widest tire
By 96t/a in forum Wheels and TiresReplies: 11Last Post: 11-03-2007, 03:44 PM -
Widest rim/tire without mods
By GNICTRY in forum Wheels and TiresReplies: 7Last Post: 11-01-2007, 10:24 AM -
widest tire on z06 replicas
By dkroshko in forum Wheels and TiresReplies: 4Last Post: 06-07-2006, 11:28 AM
