    Maryland
    2001 WS.6
    What is the widest tire I can run?
    Right now I have 315 Nitto DRs but after my Koni's and Strano's my rear tires rub during hard cornering. What is the widest tire I can run without rubbing? I was thinking of maybe throwing a 295 or 305 back there but since Nittos run small I'm not too sure how where I am now. What do you think? Also does anyone have any input on the BFG DRs? Thanks.
    Coral Springs, Fl
    Sunset Orange Metalic
    Did you get an adjustable panhard bar and some adjustable lower control arms?
    Could be your just not centered properly
    Maryland
    2001 WS.6
    I do have a adj. panhard bar but LCAs are stock. Rear looks pretty centered but is there anyway I could double check it to make sure?
    Coral Springs, Fl
    Quote Originally Posted by INeedLS1 View Post
    Well the LCAs adjust forward and back
    Is the rubbing on both sides and is it towards the front, rear, or all around th wheel wells?
    Just asking all this to save you money
    Also have you done any hammering to your wheel wells?
    Maryland
    2001 WS.6
    I haven't done any hammering. The rubbing only happens when I am cornering really hard at high speeds, but it will do it wether turning left or right.
    Coral Springs, Fl
    I suggest you get to hammering
    Its perfectly normal to have to hammer your wheel wells with wide rear tires
    If you remove the wheel, can you physically see where it rubs? If so you know where you need to hammer. Buddy had 295s and we hammered til there was no rubbing, like you said, the DRs are usually not as wide. Best advice i can give.
    Member Bowtie Guy's Avatar
    North San Diego County,CA
    2002 Z28 M6
    I am running 285/40/17 BFG G Force on ZR1 wheels with 56 offset and they have never rubbed. Been on the car 4 years,no problems.
  1. widest tire
    By Nitro_Junkie97 in forum Almost Anything Goes
    Last Post: 04-03-2008, 03:15 PM
  2. widest tire
    By 96t/a in forum Wheels and Tires
    Last Post: 11-03-2007, 03:44 PM
  3. Widest rim/tire without mods
    By GNICTRY in forum Wheels and Tires
    Last Post: 11-01-2007, 10:24 AM
  4. 99 Firehawk widest tire
    By blownh2x in forum Wheels and Tires
    Last Post: 10-24-2007, 03:51 PM
  5. widest tire on z06 replicas
    By dkroshko in forum Wheels and Tires
    Last Post: 06-07-2006, 11:28 AM
