Thread: Widest rim/tire without mods
10-31-2007, 11:55 AM #1
How wide of an aftermarket rim/tire can be on a 2000 trans am ws6 without mods?
10-31-2007, 12:08 PM #2
I was running Boyd Coddington Smoothie II's at 18"x10" with a 315 wide tire. It did rub slightly but an adjustable panhard bar fixed that up.
10-31-2007, 10:53 PM #3Crazy Canuck !
- Jun 2002
- Montreal, CANADA
17x11 or 18x11 is easily installed... gotta make sure you have a adj-PHR to minimise chances of rubbing due to GM clearances on stock PHR
Eugenio_SS
11-01-2007, 04:49 AM #4
I've heard that on the Camaro you may have to remove or relocated the bump stops. This is just what I heard as I have a Trans Am.
2002 Black WS6 A4.
FI, H/C, LT headers, full exhaust, Fast 90/90. MWC Fab 9". Subframe connectors,
Lower Control Arms, Panhard bar, Torque arm Strano Springs & Sway Bars.
Koni Yellows. FLT Stage VII trans w/ PAS3400
ASC# 4619 Conversion date was Dec 3, 2001
11-01-2007, 04:53 AM #5
so I can do a 17 or 18 by 10 without adjusting o a 17 or 18 by 11 with adj pan bars?
11-01-2007, 04:58 AM #6
With going with a 10" or 11" rim I would sudjest the panhard bar. Or take the chance of rubbing in you take a corner to hard.
11-01-2007, 05:29 AM #7
11-01-2007, 10:24 AM #8used and abused at wot
- Crystal Lake IL
Pewter- 2001 Camaro Z28 M6
I run 315x35 17 Drag radials on a 17x11 wheel. my z28 is lowered and I did not have to mod anything.
the fronts have 275 40 17.
widest tire on a 16"
By TmaxicanA in forum Wheels and TiresReplies: 4Last Post: 09-10-2010, 03:23 AM -
What is the widest tire I can run?
By INeedLS1 in forum Wheels and TiresReplies: 6Last Post: 12-21-2009, 06:11 PM -
widest tire
By Nitro_Junkie97 in forum Almost Anything GoesReplies: 22Last Post: 04-03-2008, 03:15 PM -
widest tire
By 96t/a in forum Wheels and TiresReplies: 11Last Post: 11-03-2007, 03:44 PM -
widest tire on z06 replicas
By dkroshko in forum Wheels and TiresReplies: 4Last Post: 06-07-2006, 11:28 AM
