Results 1 to 20 of 39
    DFW
    Stg IV a4
    '99 TA Ws777
    How Far Am I From a Blower?
    What mods would I need to change to go FI?
    Curtis: I got laid last night
    Curtis: 35 seconds
    Curtis: it was awesome
    Castle Rock, CO
    Montego Blue
    '07 BMW 328Xi Coupe
    You can run on a stock motor with low boost for a while but it won't last past about 110K miles. But basics are new injectors, fuel pump, forged bottom end, pistons, milled heads, custom grind cam, maybe even an iron block if you wanna get serious.
    DFW
    Stg IV a4
    '99 TA Ws777
    I have 30lb ford injectors
    Castle Rock, CO
    Montego Blue
    '07 BMW 328Xi Coupe
    Those might work. Dan should be able to clarify. I usually hear 42lb's are the perfered size but I don't know for sure. Did you check tech for some write ups?
    Senior Member Bottesini's Avatar
    Denton, Texas soon Lafayette, Louisiana
    Blue
    2002 Z28 Camaro M6
    Might be a good excuse to add a few cubes. At least you could kind of take things in steps, granted that is still a big step. If you start off with small amounts of boost you should be relatively safe for the short term.
    Castle Rock, CO
    Montego Blue
    '07 BMW 328Xi Coupe
    You'll definately want a tune to keep everything as rich as possible to keep from detonation. The stock LS1 is already like a 10-1 compression ratio so everythings gotta be remapped so you don't blow the motor.
    DFW
    Stg IV a4
    '99 TA Ws777
    Quote Originally Posted by Heartbreak1 View Post
    *ahem* Fuck Tech.
    If I buy a new bottom end, it will be a 346 or a 383. No need for an ls2 like dj.
    Castle Rock, CO
    Montego Blue
    '07 BMW 328Xi Coupe
    383 should be a good combo with the right boost. Turbo or S/C?
    DFW
    Stg IV a4
    '99 TA Ws777
    I want a Maggie! 383 would be siiiick!
    DFW
    Stg IV a4
    '99 TA Ws777
    DFW
    Stg IV a4
    '99 TA Ws777
    Damn good price.
    Senior Member
    Colorado
    pie
    You'll probably need to step up the injectors. I run 60# ones.. but of course I'm crazy and like to go overboard on everything I buy.
    It's easy to say "as long as you keep the boost low the stock block will be ok" but I had a hard time doing that. Up here I wanted more power so I went for it... and now I get to shop for a new engine.
    DFW
    Stg IV a4
    '99 TA Ws777
    Quote Originally Posted by DanWS6 View Post
    So you're saying my existing, heads/cam etc will work?
    Castle Rock, CO
    Montego Blue
    '07 BMW 328Xi Coupe
    Not necessarily. It all depends on your comp. ratio and what size cam and heads you have.
    DFW
    Stg IV a4
    '99 TA Ws777
    Patriot Ls6 'style' heads 59cc
    Comp 224/230 .581 .591 @112lsa
    Castle Rock, CO
    Montego Blue
    '07 BMW 328Xi Coupe
    112 LSA in an auto?! Thats a first for me! I thought general rule was autos didn't go over 113 LSA unless motor was fully built.
    DFW
    Stg IV a4
    '99 TA Ws777
    I wanted the nasty lope, I could give a damn. Seems to putting down some decent numbers, she doesn't hate me too much. Why? What's wrong with 112lsa?
    Castle Rock, CO
    Montego Blue
    '07 BMW 328Xi Coupe
    Heard it was rough on tranny output but since u have a built tranny I guess it doesn't make a difference.
    DFW
    Stg IV a4
    '99 TA Ws777
    Maybe that's why the stocker went out so quick
    Castle Rock, CO
    Montego Blue
    '07 BMW 328Xi Coupe
  1. Blower set-up?
    By Dr.Crash in forum Forced Induction
    Last Post: 02-10-2010, 08:48 PM
  2. blower
    By TRANS AM REBEL in forum Forced Induction
    Last Post: 12-15-2007, 07:46 PM
  3. blower cam help...
    By badazta in forum Forced Induction
    Last Post: 05-16-2007, 04:29 PM
  4. blower ?'s
    Last Post: 08-24-2006, 01:34 PM
  5. blower for a LT1?
    By 94formulaLT1 in forum LT1
    Last Post: 02-12-2006, 08:04 PM
