Results 1 to 11 of 11
Thread: Blower set-up?
02-04-2010, 09:26 PM #1TJEA Retirement Home
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
Blower set-up?
Ok so i have been some what looking at blowers recently but am trying to get some feedback. What set-up are you guys running or would you recomend? I was planing on going with the L92 heads and a pro-charger, or Is maybe someone who sells a blower H/C package? Looking to make my car a little more well mannered. Thanks for the input
02-04-2010, 09:27 PM #2TJEA Retirement Home
- Feb 2006
Stock- 2002 Camaro
Almost forgot to say what ive got done so far.......
02 SS
LQ9 408 Stroker ,M6 1LE, LT's, ORY, GMMG, STG2 LS6 heads,248/254 .612/.622, Tubular LCA's, Panhard, torque arm, tranny cross-member, upper and lower a-arms, k-member, 3 point SFC's, Baer 6 pistons up-front, stock rear
, Adj. coil-overs,
12.6@120MPH
81 Celica
18.1 @ 85MPH
02-05-2010, 02:14 PM #3
the kit that i would recommend is a Procharger D1sc with the upgraded 4.5 intercoolers or do the front mount intercooler..
that would get you in the boost range to make a great fast street car and have funn doing it.
also what fuel system upgrades have you done?
Thanks,
Mark
02-06-2010, 06:37 PM #4
02-07-2010, 06:03 AM #5
it all depends on the boost you want to run. if you get over 6-7 PSI you might want to go with the dual intank setup. that is the easiest way to go to help out with the extra fueling needed. the other way is the external pump.
the stock lines are good till about 650RWHP. 60lbs injectors should be good.
Thanks,
Mark
02-07-2010, 09:43 AM #6
I have seen and made well over 800rwhp with stock lines, 2 walbros, a FMFPR and a return.
With a forged street motor, a FMIC and a nice progressive menthanol kit such as the Alkycontrol setup seem to be the ticket.
02-10-2010, 06:29 PM #7TJEA Retirement Home
- Feb 2006
Stock- 2002 Camaro
What PSI would be safe/feasible to run? I wont be driving it much, maybe just the weekends. What kind of power increase would there be with 6-7 PSI? would it be noticeable from what i have know (since i would be lower the CR for the blower)? Im hoping for somewhere around 600RWHP. Is that attainable with a D-1sc, L92 heads, 60lb injectors, and my current set-up? Thanks
02-10-2010, 06:58 PM #8
D1sc
I would run a D1-sc right from the start
My custom auto spring tentioner system
4.5 coolers
methanol injection
02-10-2010, 07:12 PM #9
02-10-2010, 08:31 PM #10
Would like to see as well.
02-10-2010, 08:48 PM #11
go to LSXsolutions.com Pictures are up
blower
By TRANS AM REBEL in forum Forced InductionReplies: 4Last Post: 12-15-2007, 07:46 PM -
How Far Am I From a Blower?
By FuhBreezeE in forum Forced InductionReplies: 38Last Post: 11-27-2007, 08:25 PM -
blower cam help...
By badazta in forum Forced InductionReplies: 0Last Post: 05-16-2007, 04:29 PM -
blower ?'s
By Dr.Crash in forum Forced InductionReplies: 14Last Post: 08-24-2006, 01:34 PM -
blower for a LT1?
By 94formulaLT1 in forum LT1Replies: 2Last Post: 02-12-2006, 08:04 PM
