Results 1 to 15 of 15
Thread: blower ?'s
08-17-2006, 03:33 PM #1TJEA Retirement Home
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
blower ?'s
i have an 02 SS and i wanted to put on a blower. i was going to go with the procharger, but i just recently saw a 4th gen z28 on ebay with a Roots style (magnacharger) blower. does anyone know some one who could do this, and about what the price would be. thanks
08-20-2006, 09:56 AM #2
Would be somewhat pricey, you would also have too cut into the cowl, and do some fabrication.
The magnacharger was directed towards the vettes.
08-20-2006, 10:01 AM #3Blown, Stroked, & Sprayed
- Aug 1999
- No Where
I don't think its worth the effort. Go with the Procharger.
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
08-20-2006, 10:47 AM #4
Buy the procharger. You can run up to about 7psiwith no worries. Not a real hard install and you'll make about 450 hp at the tires.
08-20-2006, 11:11 AM #5Michael
In GA waving from '02 C5 LS1, Z51, D1SC, 60lb injectors,RPM level 5-4L60E, 3:42, Yank 3600, QA1-12 ways, MTI long headers, high flow cats, Borlas, Wilwood, 603rwhp, 542rwtq.(DynoJet 248-C) [email protected] on street tires, Race Weight 3,640 lbs
08-20-2006, 02:27 PM #6TJEA Retirement Home
- Feb 2006
Stock- 2002 Camaro
thanks for the advice. i was leaning more towards the procharger anyway.
08-23-2006, 04:56 PM #7
A guy that works at the local performance shop has an 02 with a magnacharger an it is badass. My be a little more costly but damn its a sweet setup.
08-23-2006, 05:20 PM #8Junior Member
- Jul 2006
- Richmond
Will the stock rear end and tranny hold this much HP?
08-23-2006, 06:02 PM #9
I've been making 475 for along time on all stock internals tranny an engine.
08-23-2006, 06:04 PM #10Junior Member
- Jul 2006
- Richmond
Thanks. I 'm usually an easy driver and don't lauch it hard. I've always wondered just how much they will take.
08-23-2006, 06:07 PM #11
The stock rear end will stand up pretty well with an automatic and a high stall converter because you pre-load the drive train before the power hits. Now with a stick it's a different story. You need 'heavy duty' rear gears otherwise you will wind up breaking stuff like the right side differential output shaft especially if you're dropping the clutch at high rpms with sticky tires. BUT the automatic is a
weak link in high hp applications and will eventually 'give up the goast'. Mine lasted about two years before I got a heavy duty re-build designed to handle more power.
08-24-2006, 08:59 AM #12
08-24-2006, 12:10 PM #13
08-24-2006, 12:38 PM #14
None taken.........just a little confused.
How much boost ar you running to bring your numbers up that high?
08-24-2006, 01:34 PM #15
Blower set-up?
By Dr.Crash in forum Forced InductionReplies: 10Last Post: 02-10-2010, 08:48 PM -
blower
By TRANS AM REBEL in forum Forced InductionReplies: 4Last Post: 12-15-2007, 07:46 PM -
How Far Am I From a Blower?
By FuhBreezeE in forum Forced InductionReplies: 38Last Post: 11-27-2007, 08:25 PM -
blower cam help...
By badazta in forum Forced InductionReplies: 0Last Post: 05-16-2007, 04:29 PM -
blower for a LT1?
By 94formulaLT1 in forum LT1Replies: 2Last Post: 02-12-2006, 08:04 PM
is showing over 20psi!!!
