Thread: Low numbers...?
10-08-2007, 09:30 AM #1Junior Member
- Oct 2007
- Lancaster, PA
Pewter- 1999 SS Camaro
Low numbers...?
Just dynoed my car a few weeks ago and was disappointed at my numbers. I got 365/355 on a Dynojet. It should have been closer to 400RWHP. It's a "cam only" '99 LS1 SS Camaro with 70,000 miles with typ bolt-ons. I still have the LS1 intake which I know is hurting me maybe 10-15hp. The graph is attached.....
PatrickG Custom Spec Cam
Dur @.050 230/230
Lift .612”/.592”
LSA 110 +4 advance
Mods List:
-LT headers with 3" true duals with Xpipe, no cats, no EGR
-Patriot Extreme springs, Comp hardened pushrods, LS6 ported oil pump
-LS2 timing chain, LS7 Clutch, MTI lid with K&N, fernco, Granatelli MAF
The A/F was around 12.6 and 26* timing. Motor runs awesome 100%, no smoking, no missing, drives very good and pulls hard. Sorry, I don't have any numbers before the cam. Any ideas on what I can check or what may have caused the low numbers? Thanks
10-09-2007, 05:29 PM #2
I'm assuming you got a tune with that cam. I'd think about ditching that granatelli maf or maybe do another couple pulls with a stocker and see what happens, I've never heard anything good about gran maf's. With that cam the ls6 would help alot I would put a solid 15hp for the ls6 with your mods that ls1 manifold is a choking point for your motor.
On a side note your numbers make me feel good cause I have no cam just bolt ons and put 358hp/369ft lbs. I'm beinging to think my car is a factory freak.05 PBM GTO
Cold Air Inductions CAI,Relocated IAT with omega,Slp Predator tune,Flowmaster axle back with H pipe,Custom tuned TCM.BC Racing coil overs
Sold 01 z28
10-10-2007, 02:17 PM #3Junior Member
- Oct 2007
- Lancaster, PA
The guy who tuned it showed me an '02 Camaro Dyno graph with just headers and exhaust who pulled 368hp. I was pissed because I have all these mods done including a cam, and 3 less hp! He said the '99 heads are hurting me some, but I thought they were pretty close to the 01-02 heads?? I also asked him if the Granatelli MAF could be hurting my numbers, he said NO because he just tuned it and it makes no difference if it's stock or a granatelli, it will work exactly the same. I too heard that a lot of people have problems with those Granatelli MAF, even though he said it's fine,I'm still temped to try a stock one...
10-10-2007, 06:06 PM #4
I'm pretty sure there were no changes to the heads other than the valve cover bolt pattern other than that they are the same as any other year. The only internal differance was cam 98-00 had a larger cam than 01-02. One other thing that would affect your numbers is the ls7 clutch, its an extra 8lbs heaveir, with that being rotational mass its going to have more of an effect on hp. It's not going to be a huge loss but I would gues in the 8-10 hp range. With that and the lack of ls6 mani thats an extra 20-25hp which would put you in the 385-390 range which sounds alittle better for your mods. This is kinda an obvious one but be sure you've got all your regualar maintence done, fluids, filters, plugs wire ect.
As for the maf like I said I have heard nothing good about them. I've heard over time they loose there calibration causing problems. This is all hearsay but there's a reason 99% of the guys making big numbers still run a stock maf.
10-11-2007, 07:09 AM #5Junior Member
- Oct 2007
- Lancaster, PA
Thanks for your help JonB, I might just have to try a stock MAF. It's the only thing I have on my car that's different from others have that are making close to 400rwhp cam only. The Granetelli MAF was already on there when I bought the car, thats the only reason i have one.
10-11-2007, 08:49 PM #6
Always remember dyno numbers mean absolutely shit. Just take it to the track and see what she will run. As said in previous post put your stock MAF back on and try again I have heard of people losing 10-15 hp with the gran MAF.
10-12-2007, 08:54 AM #7Junior Member
- Oct 2007
- Lancaster, PA
10-12-2007, 03:20 PM #8
Yes even with tuning I couldnt tell you why but I have seen and heard about people losing power with the granatelli MAF.
10-30-2007, 03:16 PM #9All Go No Show
- Oct 2007
- New Jersey
- 2002 Z28
Your tuner is right nseldy the 853 cylinder heads on your car that are found on 98-00 f-bodies do not flow as much CFM as the 2001-2002 241 casting cylinders heads..
Along with you still having a LS-1 Intake is hurting you also..
I agree with everyone else Lose the Granatelli MAF
Because if your tuner is any good he can tell by viewing your Maf tables if you require a bigger Maf or descreening of the stock Maf..
But with the power you are making you definitely don't need a larger than stock diameter Maf..
11-01-2007, 06:21 AM #10
its unanimous on the MAF. I have a gran. MAF and I have had nothing but problems, tuned to 13.0 A/F and she will all of a sudden just go rich on her own down to 11s.
But like stated above, numbers do not mean shit. Not to mention, shops can inflate ones numbers very easily. The shop you took it to could have easily made it show about 40 HP higher. Be happy with the low number and go spank some higher numbers who like to brag about their dyno queens. LOL. If you run a LT, bolt-ons only car that has similar numbers just watch how you pull away, that will tell you better than the dyno on how your car ACTUALLY runs.
11-27-2007, 09:42 AM #11Internet Police
- Apr 2007
- San Jose
Black- 2003 Mustang Cobra
thats exactly what i was gonna say. ^^^ Race someone with the same or slightly less mods and compare that way.
11-27-2007, 09:49 AM #12Slow'er'Ass
- Thornton, CO
Killer powerband though.
I run 6 degrees more timing than you do, maybe bump it up a little. Although, your tuner would know best with that cam. I know very little about tuning for a cam.
The Numbers are in!!!!!!!
By FSANE in forum Almost Anything GoesReplies: 17Last Post: 04-25-2008, 08:56 PM -
Tr230 dyno numbers 98 heads=bad numbers?
By phoenix1987 in forum Dyno InformationReplies: 7Last Post: 09-11-2007, 08:33 AM -
how are these numbers? H/C
By Dr.Crash in forum Internal EngineReplies: 8Last Post: 07-09-2007, 05:33 AM -
Are my numbers ok?
By Nate00SS in forum Rocky Mountain MembersReplies: 23Last Post: 01-20-2006, 01:40 PM -
lt1 hp numbers
By Mr. CarelessAndImprudent in forum LT1Replies: 6Last Post: 01-04-2006, 05:11 AM
