08-26-2007, 12:32 PM #1Junior Member
- May 2006
- Minnesota
Red- 1987 Trans Am
Tr230 dyno numbers 98 heads=bad numbers?
I had my car on the dyno yesterday and was kind of shocked at my low numbers. I have long tubes, Ls6 intake, full comp cams valvetrain, underdrive pulley, CAI, tune, no cats, TR230 (230/224 111LSA) and 98 heads. I put down 350rwhp and 350 rwq. I found out the dynojet I used is 10rwhp and 10rwq off. So I am at 360 rwhp and 360rwq. This is through a six speed and a 10 bolt.
I was hoping for 375+. Do these numbers seem low to anyone else? I was told that the short block has around 62K on it. The cylinder walls looked very clean and felt very smooth when I asembled the motor. The car runs very strong and the dyno graph was very consistant. Are the 98 heads that bad? I know some people have had good luck with them cam only, but how bad are they?
I know there has been some porting done to the intake ports, but that is all. I think it was a "port them at home project" by the last owner. My tuner and buddies think that the port job could have made the heads worse. I am thinking so as well.
I am going to put on a set of 2000 heads off of my buddys 2000SS and dyno it again.
08-26-2007, 12:34 PM #2
08-29-2007, 05:51 AM #3Simpsons Did it!!
- Mar 2007
- Minnesota
83 Z28 new project- 98 Formula WS7-sold:(
Did you go to Doug Rippie's for the MN F body club dyno day?
08-29-2007, 10:50 AM #4Junior Member
- May 2006
- Minnesota
Red- 1987 Trans Am
No.
The A/F was good. 12.5-13.4 . Tuned by a friend of mine. For mods, look in the first post. Not really a lot of work when the ls1 is in a third gen. Just want to see how different the numbers are. I think the home porting job is one of the main reasons for the lack in power. And no I didn't port them, I got them that way.Who tuned it?? How was the A/F?
What other mods?
08-29-2007, 02:17 PM #5Slow'er'Ass
- Thornton, CO
What kind of dyno??
And yes, the home ported heads could be a problem. Distorted flow will kill power.
08-29-2007, 06:51 PM #6
Hey, yea it seems low, i have a tr224 with longtubes on cats, no ls6 and i made 361 361 rwhp and trq on a dyno jet
08-29-2007, 07:01 PM #7Junior Member
- May 2006
- Minnesota
Red- 1987 Trans Am
09-11-2007, 08:33 AM #8
You have a pretty decent setup for the TR230 reverse split cam. With a proper tune you should be right around 400wtq/hp. Sounds like the home porting job has damaged your heads.
DYNO Numbers
By 35th-ANV-SS in forum Dyno InformationReplies: 8Last Post: 09-19-2009, 03:34 PM -
LOW dyno numbers?
By 05gtoautoX in forum GTOReplies: 11Last Post: 10-27-2008, 11:34 AM -
02 SS dyno numbers??
By Ripper415 in forum Camaro / SSReplies: 42Last Post: 01-21-2007, 12:16 PM -
New Dyno Numbers...
By Blown Interceptor in forum Western MembersReplies: 17Last Post: 10-29-2005, 09:06 PM -
383 FI Dyno Numbers
By Ed Blown Vert in forum Dyno InformationReplies: 4Last Post: 10-17-2005, 09:26 AM
