Thread: how are these numbers? H/C
07-07-2007, 12:15 PM #1TJEA Retirement Home
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
i have a 02 SS M6 with SLP LT's, 80mm TB, 36lbhr bosch injectors. LS6 heads, 230/230 .600 lift cam, BMR torque arm, tranny crossmember, LCA's,panhard rod. with a tune it put out 397.5RWHP and 385RWTQ. i ran a 12.7 @115 in the 1/4 on street tires. does this sound like low numbers? i have heard of some people with over 400rwhp with just a cam. thanks for the input
07-07-2007, 12:23 PM #2Slow'er'Ass
- Thornton, CO
Sounds a little low.
Although trapping 115 sounds like it makes more than 397RWHP if it is full weight.
07-07-2007, 01:38 PM #3TJEA Retirement Home
- Feb 2006
Stock- 2002 Camaro
yup its full weight, plus i has about 100lbs in stero stuff and a 4 point roll bar. when they did the dyno they told me it was SAE corrected, what does that mean?
07-07-2007, 01:40 PM #4Slow'er'Ass
- Thornton, CO
Corrected for weather conditions to a standard number. That way numbers from across the country look the same regardless of altitude, heat, etc...
Do you know what kind of dyno it was?
Do the numbers matter to you if it runs strong? Wondering...because my dyno numbers don't matter much to me. Tuning tool...that is it.
07-08-2007, 12:33 AM #5
115 trap sounds about right for your 400rwhp & added weight. Insofar as your numbers, they seem a little low. Are you running cats? Factory rear and gears? Are the springs up to that cam lift?
07-08-2007, 05:04 AM #6Senior Member
- Jul 2006
- indiana
black, 05 Roush- black, 99 T/A WS.6
I might have expected another 10-15 hp but really that isnt too bad. As far as guys having over 400hp with just cam.,.....they are probably running a much larger cam, TSP MS4 or something similar. Port those LS6 heads and I would think it would be safe to expect to have around 430hp. Also your 1/4 mi. times sound like you are having traction issues, try some drag radials and practice.
1999 T/A WS6 Black
-------SOLD
05 mustang Roush sport;
DOB manifold, m122 SC, 47lb injectors, gt500 TB, roush TVS CAI, Detroit rocker SC grind camshafts, Mac LTs, off road x, roush off road mufflers, roush short throw shifter, kenne bell BAP, Brenspeed 93 octane tune. 479rwhp 436ftlbs SAE.
07-08-2007, 10:38 PM #7TJEA Retirement Home
- Feb 2006
Stock- 2002 Camaro
yes i do have cats, and i am getting some drag tires soon. i have 3.73 with a zexel high torque diff in the factory rear. when i did the cam i replaced the factory spring with the patriot gold series springs. i have thought about taking the cats off, but what kind of power gain could i expect? is it worth it? thanks for all the input.
07-09-2007, 04:19 AM #8Member
- Aug 2006
- 29 palms
black- 2000 pontiac TA vert
Those numbers definitly seem low especially for the cam you have.
2000 TA vert stock
07-09-2007, 05:33 AM #9member since may 2000
- Dec 2002
- n/w chicago
the trap seems just about right. youre e.t, well, it sucks. get better tires.
your dyno numbers do seem alittle low.2000 nhra edition formula
a few bolt ons, 379 rwhp
11.96 @113.25
The Numbers are in!!!!!!!
By FSANE in forum Almost Anything GoesReplies: 17Last Post: 04-25-2008, 08:56 PM -
Low numbers...?
By nseldy in forum Dyno InformationReplies: 11Last Post: 11-27-2007, 09:49 AM -
Tr230 dyno numbers 98 heads=bad numbers?
By phoenix1987 in forum Dyno InformationReplies: 7Last Post: 09-11-2007, 08:33 AM -
Are my numbers ok?
By Nate00SS in forum Rocky Mountain MembersReplies: 23Last Post: 01-20-2006, 01:40 PM -
lt1 hp numbers
By Mr. CarelessAndImprudent in forum LT1Replies: 6Last Post: 01-04-2006, 05:11 AM
