Results 1 to 11 of 11
Thread: Rubber Spring Seats (rear)
09-30-2007, 07:46 AM #1
Can anyone tell me... how tall they are roughly?... Cause I bought some cheap replacement ones...and my car looks like it's sagging in the rear... after I put on the Eibach Springs...
they are maybe half an inch on a good day (the replacement ones)...
09-30-2007, 11:00 AM #2
To answer your question exactly, the rubber spring isolator or seat is at least 1 1/2 inches thick. But by the time you seat the to of the spring into it, it only accounts for a 3/4 in difference in the height of the car.
I installed Eibach ProKits on it a couple of weeks ago and kept the stock rubber seat/isolator and the rear dropped to the point that the top of the wheel opening on the Qtr. Panel is about 1/2 to 3/4 inches from the top of the tires! I can't imagine what it would have looked like if I did the hose mod.
09-30-2007, 12:07 PM #3
well then I guess the cheap thing I bought...is probably close to less then 1/4 of a inch just on the weight on it... :s damn... well I guess I'll go and buy the Stock ones... and about the hose thing... can you do that to get a little more height out of it?
09-30-2007, 06:10 PM #4
No, the hose mod actually drops it even more. It consists of taking rubber hose and installing/sliding it onto the top 1 or 2 coils of the OEM spring, then removing the OEM rubber isolator/seat. Some people will do this instead of installing lowering springs, which gives you a 3/4 in drop. Did that make sense?
09-30-2007, 06:12 PM #5
09-30-2007, 06:20 PM #6
10-02-2007, 06:39 PM #7
10-02-2007, 06:41 PM #8
10-02-2007, 06:43 PM #9
10-02-2007, 06:46 PM #10
10-03-2007, 12:57 PM #11
Help Please: Need rear-spring isolators.
By oldskoolrcr in forum Suspension and HandlingReplies: 2Last Post: 03-23-2008, 07:26 AM -
GM ZO6 wheels/tires..race rubber rear...new fronts
By SSmaro in forum Rocky Mountain MembersReplies: 5Last Post: 09-13-2007, 04:15 PM -
GM ZO6 wheels/tires..race rubber rear..new fronts
By SSmaro in forum Parts For Sale / TradeReplies: 4Last Post: 08-20-2007, 06:23 PM -
Rear alignment issues after removing rear spring isolaters, adj trac bar fix it?
By anestech* in forum Suspension and HandlingReplies: 1Last Post: 06-19-2007, 07:06 PM -
Rear spring squeak TSB???
By Warbird in forum Suspension and HandlingReplies: 3Last Post: 09-14-2005, 02:57 PM
