    Ohio
    97 Formula
    Rear spring squeak TSB???
    Ok, so I found this on a 4thgen FAQ.
    Q: What's that hollow clunking noise from the rear over bumps?
    A: A clunk is most likely the rear springs which are "popping" over bumps. If you have squeak, it's probably caused by the metal springs rubbing against their metal perches. In either case, a Technical Service Bulletin (#B005001) calls for the placement of rubber isolators at the bottom of the springs to act as cushion. You can probably do this yourself by wrapping some rubber hose around the bottom coil (down by the axle) of each spring.
    It sounds like the problem I have, but I can not find the TSB on the NHTSA website? Anyone have anymore information?
    Ohio
    97 Formula
    Anyone?
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    try torquing your LCAs
    Eugenio_SS
    Ohio
    97 Formula
    I've already done that.
  1. Squeak/Creak from the rear!
    By speedyWS6 in forum Firebird / WS6
    Last Post: 09-23-2014, 04:17 AM
  2. Right Rear squeak
    By Red99TA in forum Suspension and Handling
    Last Post: 05-01-2010, 07:17 PM
  3. Question: Squeak from rear suspension
    By psycho_puppies in forum Firebird / WS6
    Last Post: 12-31-2009, 07:12 AM
  4. Help Please: Need rear-spring isolators.
    By oldskoolrcr in forum Suspension and Handling
    Last Post: 03-23-2008, 07:26 AM
  5. Replies: 1
    Last Post: 06-19-2007, 07:06 PM
