    Member speedyWS6's Avatar
    Sep 2009
    U.K.
    2002 WS6 TA
    Squeak/Creak from the rear!
    Hi Guys,
    For a good while now i have had a bit of a creaky squeak from the rear of the car and
    it has predominately been from the passenger rear corner but is now, it seems,
    in evidence on both rear corners.
    On very slow maneuvering with the car going backward and forward it creaks at the
    point the car stops and if you were to push the corner up and down it does the same noise.
    It is ok once driving as, i suppose, the car is not bouncing up and down to the same degree?
    Is this a dry bush of some sort or do i maybe need new shocks on the back? maybe it is where
    the springs seat? Just guessing here!
    I thought about aiming WD40 around strategically bit by bit on different suspects to narrow it down to a non
    squeak/creak situation.... good idea, or not? Once located i can renew as needed i would imagine?
    Any thoughts on a "usual suspect"?
    Thanks guys...
    Trev
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    What condition are your bump stops? I don't think I saw it in your post but does it do it while turning too? The things I would check would be your sway bar bushings, shocks and springs, and bump stops. How many miles are on your shocks?
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    You sure your y-pipe is not coming into contact with the upper pan hard bar where it crosses over/above the rear end?
    I'd crawl under the car and look for where metal might be coming into contact with metal. The metal will be shiny.
    Sep 2009
    U.K.
    2002 WS6 TA
    The shocks, i reckon, are the original so 48k
    I would not imagine the bump stops as it creaks whilst stationary if you
    push up and down on the corners.
    Its an up and down issue but not to any form of limits or stops. Just a very light
    push up and down and "creak creak creak"!!
    The only turning involved is slow maneuvering whilst barely moving.
    Inclined to think bushes rather than shocks but i don't know!!
    Jon... Good thought as it is a new Y but i have to say i have been a bit lax in
    dealing with this prob and it has probably done it ever since i have had the car so not
    a new thing at all!!
    All stock out back?
    I have lubed bushing faces with Synthetic Caliper Grease before to quiet them down. You could also have a loose bolt in the LCA's or panhard that is allowing something to move around a bit more than it should. Easy to drop each arm, one side at a time, and the panhard to check things out when you get a chance.
    Old and new could have been hitting. I would check that area anyway. Won't take but 15 seconds. Aside from that, I'm not aware of any common noises back there. Jeff and others have given good advice.
    Also check to ensure it's not your hatch. There's rubber stops that can be adjusted if the hatch lid is not closing as tightly as it should.
    Member RONS98TA's Avatar
    MARYLAND
    BLACK
    1998 PONTIAC TA
    Could also be the rear sway bar bushings where the rod actually pases through the bushings. As you have already mentioned, the WD40 trick is where I would start though.
    Sep 2009
    U.K.
    2002 WS6 TA
    Thanks for the input guys,
    I will get busy at the weekend to narrow this problem down.
  1. Right Rear squeak
    By Red99TA in forum Suspension and Handling
    Last Post: 05-01-2010, 07:17 PM
  2. Question: Squeak from rear suspension
    By psycho_puppies in forum Firebird / WS6
    Last Post: 12-31-2009, 07:12 AM
  3. T-Top squeak..
    By silverWS6 in forum General Help
    Last Post: 10-30-2009, 09:32 AM
  4. bad squeak what could it be?
    By bgable in forum Suspension and Handling
    Last Post: 12-02-2007, 06:12 PM
  5. Rear spring squeak TSB???
    By Warbird in forum Suspension and Handling
    Last Post: 09-14-2005, 02:57 PM
