Thread: T-Top squeak..
10-26-2009, 09:12 PM #1
T-Top squeak..
WTF! Its annoying as hell!
Why did it start squeaking? I noticed it started happening after i put my Bisteins in. Do I have to adjust my t-tops or what? Or will subframe connectors fix this?
10-26-2009, 09:15 PM #2
It's prolly not that involved of an issue. Maybe a shot in the dark here but sounds like your T gaskets are dry. Gm makes a treatment for them I just use Blackmagic on them to keep them freash and moist..
10-26-2009, 09:51 PM #3
Like in between the gaps? Where they seal?
10-26-2009, 09:53 PM #4
10-27-2009, 06:21 AM #5Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
This happened to my buddies 3rd Gen...Armor All on all of the gaskets (edge of the actual t-top and the "U" in the roof) worked great.
10-27-2009, 09:26 AM #6
Thanks guys! Im gonna look into it right now
10-28-2009, 04:25 PM #7
Apply spray silicone to a shop rag and wipe down your seals. The application should be wet. Also good to do your door and hatch seals while you are at it. I think the GM stuff is a little pricey.
10-29-2009, 02:36 AM #8
spray silicone in the holes where the t-top pins (not sure if that the correct name or not) go. That took care of my t-top squeaking.
10-30-2009, 06:39 AM #9
10-30-2009, 06:49 AM #10
I quit using armor all about 15 years ago when I discovered black magic lol. Black Magic last 10X as long as armor all, and can be used on nearly evrything in/on the car, plastic/rubber. Not so mention it smells 100x better too lol..Just do'nt use it on the steering wheel.
10-30-2009, 07:41 AM #11
I like black magic too......
10-30-2009, 09:32 AM #12
sfc's will do the trick if the above mentioned doesn't
Question: squeak
By edrvsqz1980 in forum Firebird / WS6Replies: 11Last Post: 10-14-2010, 06:04 PM -
Help!!! I've got a squeak!!!
By PFirehawk in forum External EngineReplies: 0Last Post: 05-19-2009, 12:01 PM -
bad squeak what could it be?
By bgable in forum Suspension and HandlingReplies: 4Last Post: 12-02-2007, 06:12 PM -
Squeak, Squeak, Squeak
By sfletch2000 in forum Firebird / WS6Replies: 11Last Post: 11-24-2007, 02:18 PM -
Squeak!!!
By TA76 in forum Suspension and HandlingReplies: 5Last Post: 02-20-2006, 01:01 PM
