    Moore, Oklahoma
    Artic White
    2002 M6 WS6
    Suspension noise after lowering???
    Hey guys, new member here. I just had Hotchkis lowering springs put on and now when I hit bumps there's a loud rattle (clanging) noise coming from the front end. I took it back to the shop and they couldn't find it. Any ideas? It almost sounds like something's lose but everything seemed tight when he re-examined it.
    Thanks for any help!!!
    how many miles are on your car? If it's higher [over 70k] you're shocks are probably warn out and the agreesive drop in height is making it hard for them to do their job.
    rule for lowering: always do shocks AND springs at the same time.
    Moore, Oklahoma
    Artic White
    2002 M6 WS6
    yeah it just turned over 10,000 miles. I have a friend that lowered his 00 ws6 with the eibach kit (even more drastic) and he's running his stock shocks with over 130,000 miles and has no noises. That's why it was throwing me off. His drop was about 1.5" and mine was exactly 1". Still think it may be a shock issue with so few miles and only a 1" drop???
    Thanks for your reply.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    sometimes, they don't get the shock nut tight enough up top. so, the shaft moved around. i've had it happen.
    Moore, Oklahoma
    Artic White
    2002 M6 WS6
    You have to forgive me... I'm not a suspension guy. Is this something that can be corrected if he were to tighten it back? Because he re-tightened everything but it still has that sound. Does something need to be re-adjusted or should I send it to another shop? How did you get yours fixed Mrr23? Thanks for the advice.
    Jesus died to save you! Killer_bluebird's Avatar
    North Olmsted, OH
    You have to pull the strut out and retight the bolt that bolts the shaft to the upper mount. Also check your swaybar endlinks. But like it was mentioned before the shock is not properly valved for a spring that has 233 pounds of pressure over the stock spring. Will it work with that spring yes but not well, how long will it last? not a lot before it starts wearing out.
    2000 NBM Camaro Z28
    Mods:
    SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
  1. My Lowering And Suspension Project
    By j nix in forum Suspension and Handling
    Last Post: 05-24-2011, 01:17 PM
  2. Upgrading Suspension/Lowering
    By TheShadow in forum Suspension and Handling
    Last Post: 03-01-2011, 10:59 AM
  3. suspension noise i think??????
    By DaddysZ28 in forum Suspension and Handling
    Last Post: 07-02-2010, 09:57 AM
  4. 3 mechanics later... and still front end noise after lowering???
    By architect7 in forum Suspension and Handling
    Last Post: 10-10-2007, 10:37 PM
  5. Front Suspension noise!
    By Rikki_SeVeN in forum Suspension and Handling
    Last Post: 08-24-2007, 09:00 PM
