Thread: suspension noise i think??????
06-27-2010, 07:49 PM #1
I ordered the UMI 3-point sfc's. The car handles great and feels alot more solid, however, since having them installed, I keep getting this banging noise that sounds like it's coming from under the drivers seat, as if the sfc's are hitting the bottom of the car or something. It's not very consistent, and sometimes it's worse then others. Love the product, don't love the weird banging noise. Any help or advice would be greatly appreciated!!! Anyone else having this same issue????
06-28-2010, 07:18 AM #2Life In The Fast Lane..!!
- Jul 2008
- SoCal, SD
Brickyard 400 Trac Car#10- 35th Camaro SS/LE Vert
So I take it you didn't have this issue prior to the install. Are they bolt or weld in?
If there bolt in try retorquing the bolts and check for other clearance issues. Sometimes if parts are installed on a lift or stands the chassis isn't loaded but once lowered back down and driven things settle and shift and need to be retorqu'd.
06-28-2010, 11:06 AM #3
I say it is your lower control arm thru bolts not being tight enough. Are your sfc's bolt or weld in?
06-28-2010, 01:43 PM #4
i had same problem sounds like. they were weld ins and i just bolted them in real tight to lca's. i took back up there and he tacked up as much as he could and no more sound.
06-28-2010, 10:34 PM #5
their the weld-ins. when i finally get some time off work i'll have to try to crank on those bolts, and hopefully that resolves the issue. thanks for all the advice.
06-29-2010, 08:47 AM #6Member
- Jan 2009
- Pa
Hello
Sorry to hear about the noise issue. Seeing how they are the weld on version. I would suggest trying to torque down the hardware to 90ft lbs. That is the only thing it can be and its just transferring the noise through that chassis. But I am sure once they are tightened the problem will stop. If you have any other questions feel free to ask or give me a call. I will be in the office M-F 8am-4:30pm EST.
Thanks
Brad
07-02-2010, 09:57 AM #7Member
- Nov 2009
- North Carolina
Black- 2001 Camaro Z28
same problem here i took out the bolt put a little grease on it and retightened and it stopped
Rear suspension noise '02
By johnfin in forum Firebird / WS6Replies: 16Last Post: 04-23-2013, 01:46 PM -
Help: Shock/ rear suspension noise
By 90ARAPAJ in forum Firebird / WS6Replies: 13Last Post: 11-05-2011, 04:14 AM -
Suspension noise after lowering???
By arkitket in forum Suspension and HandlingReplies: 5Last Post: 09-24-2007, 01:48 PM -
Front Suspension noise!
By Rikki_SeVeN in forum Suspension and HandlingReplies: 4Last Post: 08-24-2007, 09:00 PM -
FirstPost - Suspension/Wheel Noise
By Gorkass in forum Suspension and HandlingReplies: 1Last Post: 06-26-2007, 11:12 AM
