10-10-2007, 03:49 PM #1Member
- Sep 2006
- OKC
Artic White- 2002 ws6
3 mechanics later... and still front end noise after lowering???
Hey all. I posted a suspension thread about a month ago after lowering my 02 ws6 with the hotchkis spring set. I mentioned that now when I hit a jarring bump there's a rattle/light clanging noise on both side of the front suspension. I've had 3 shops look over everything and nothing can be found. The last guy said he couldn't even hear anything. It has 10,000 miles on it and my last guess is maybe it is the shocks. Could the shaft inside the shock be rattling after only an inch drop? Another member on here has an 02 with stock shocks and the hotchkis set up and reports no noises. So I guess my question is, shocks making the racket?
Thanks for the help again.
10-10-2007, 04:06 PM #2Member
- EL PASO TX.
RED- 1998 CAMARO Z28
Check the bushing from the sway bar mine did a weird noise when got a bump.
good luck
10-10-2007, 04:40 PM #3
maybe they did not tighten the top nuts for the shocks enough.
10-10-2007, 10:37 PM #4
Front end noise
By homickb in forum Suspension and HandlingReplies: 30Last Post: 07-06-2012, 05:13 PM -
front end noise
By rsg98Z28 in forum General HelpReplies: 1Last Post: 11-13-2008, 09:35 PM -
Lowering front end of car?
By Frankthetank in forum Suspension and HandlingReplies: 4Last Post: 11-17-2007, 07:37 AM -
Suspension noise after lowering???
By arkitket in forum Suspension and HandlingReplies: 5Last Post: 09-24-2007, 01:48 PM -
would lowering the front end help on racing?
By greatwhiteZ28 in forum Drag RacingReplies: 0Last Post: 08-30-2007, 04:42 PM
