Results 1 to 14 of 14
Thread: Horn stopped working?
09-21-2007, 12:36 PM #1
all of the sudden my horn just stop working what could this be how can i fix this..and anyone elses horn not owrk i just thought of it as one of those things that would always work and never go out but guess i was wrong?
09-21-2007, 01:56 PM #2
09-21-2007, 02:58 PM #3
just start using your finger
09-21-2007, 05:49 PM #4
already started using that method joe lol but what do horns run price wise?
09-22-2007, 07:45 AM #5
well I did have one but left it on the car after all the other stuff was taken off and now its probably crushed I wouldn't think they would be very much
09-22-2007, 05:34 PM #6
Well, before you go buyin a new horn, Did you check to make sure that it hasn't come unplugged or that the fuse hasn't blown? Use a ohmeter to see if you've getting power to the horn also if both of those pan out. If that is all fine then I wouldn't expect the horn to be very expensive at all. I know you can get air horns at stores around here for $30. Not stock, but a hell of a lot louder. I haven't put them on here, but I recently put them on my moms huge axx van. It had a pidly little horn that sounded like a bicycle horn. Anyways my mom bought it and I put it on there for her.
09-22-2007, 06:04 PM #7Impwnded
- May 2007
- Davenport, Iowa
Bright Red- 1999 Trans Am Ws6
I have had both horns go out on me. High Note, and Low Note. Under the passenger side on the trans am, front corner, there is a little panel that drops down and you can see both horns. They have little trumpet on them. However, I suggest dropping the entire panel down from car to replace them. I paid 120 dollars on eBay and bought a ferrarri horn, but I think stockers are only like 14 dollars a piece on eBay, brand new ones I mean.
Out of curiousity, was it just one note working before it stopped? Or did both ones quit at same time?
09-22-2007, 07:52 PM #8Senior Member
- Jul 2007
- pocola oklahoma
black- 2002 firehawk 94 Z28
if it is your horn that has quit, there are guys parting out there cars on this site im sure you could get one cheap.
09-23-2007, 10:05 AM #9
k i check all those out thanks
09-23-2007, 07:46 PM #10
Does it work when you use the car alarm to turn lock and unlock it?
09-23-2007, 08:16 PM #11
if i completely went out...check the fuse.....
09-23-2007, 08:17 PM #12
[QUOTE=Smkn_TA;1024484] I paid 120 dollars on eBay and bought a ferrarri horn, but I think stockers are only like 14 dollars a piece on eBay, brand new ones I mean.QUOTE]
bet it sounds EXOTIC....
how did you end up installing it?
09-24-2007, 11:26 AM #13
it still works when lock it just doesnt work on the steering wheel?
09-24-2007, 02:35 PM #14
Did you check the fuse inside the cabin? It could be blown.
If I remember correctly there is a seperate one that works with the alarm in the engine bay. I'll have to check mine when I get off work.
Help: HELP!!! ABS and ASR Stopped Working!!!
By NastySS in forum General HelpReplies: 23Last Post: 06-14-2012, 05:52 AM -
Help: My A/C stopped working WHILE DRIVING.....HELP!!!
By NastySS in forum General HelpReplies: 25Last Post: 06-13-2012, 04:45 PM -
Question: Horn not working
By wdpryor in forum General HelpReplies: 1Last Post: 08-10-2010, 06:27 PM -
2001 TA Horn not working
By bobby c 01ta in forum General HelpReplies: 1Last Post: 06-01-2007, 07:07 PM -
alarm stopped working
By blky2kd in forum Stereo and ElectronicsReplies: 3Last Post: 07-18-2006, 12:42 PM
