Results 1 to 20 of 26
    NastySS NastySS's Avatar
    West Chester, PA
    2001 Camaro SS 1LE
    My A/C stopped working WHILE DRIVING.....HELP!!!
    Hello All,
    I have a 2001 Camaro SS, 6-Spd, 93,000 miles, and I am the original owner. I was driving the car yesterday with the A/C running fine and cold. All of a sudden, the air started coming out warm. I pulled over and noticed the A/C Compressor Clutch was no longer spinning. I have never had a problem with the A/C prior to this. I immediately checked for a blown fuse. Under the hood in the foreword most of the 2 fuse bays, I saw on the lid over the fuses: "A/C COMP". This seems like an A/C Compressor Relay rather than a fuse. You can't tell if it is blown. It is a little gray plastic box with 4 prongs on the bottom. I went to a auto parts store and bought a new one. The guy there told me he sells about 20 a day, and it is most likely my problem. Well, I put the new one in, and it DID NOT FIX THE PROBLEM. I did pull it out and try it turned 180 degrees as well. As a side note, the drive belt is fine, the Freon level is fine, and I was able to reach in the engine compartment and spin the A/C clutch by hand easily, so it doesn't seem to be seized.
    Any help with other things to check out/try would be GREATLY APPRECIATED. Thanks.
    Tom
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I just assisted my shop foreman with a replacement on a TrailBlazer. He told me the magnets inside the compressor fail, causing the compressor shutdown. The pulley will still spin, but the compressor is completely useless. How many miles on your car?
    West Chester, PA
    2001 Camaro SS 1LE
    I put that "93,000" in the first sentence of my post. Thought it was important.
    North Jersey
    2004 GTO M6
    Whoops!! Still a little sleepy.
    There weren't any loose connections at the compressor, right?
    West Chester, PA
    2001 Camaro SS 1LE
    No problem. That is one thing I did not check. Do I need to get it up on the car ramps to check that out? Where is the connection?
    West Chester, PA
    2001 Camaro SS 1LE
    I saw an electrical plug near the front of the compressor, and it is plugged in tight.
    North Jersey
    2004 GTO M6
    Ok. Sounds like a compressor failure to me.
    agree
    West Chester, PA
    2001 Camaro SS 1LE
    Thanks all. I just need to verify if there is power going to the plug, that plugs into the compressor. One thing I am slim on is electrical diagnostics, and I don't have a proper tool to check it.
    Arizona
    A simple $5 test light will tell you if you have power to the compressor. I'm thinking you probably do and the compressor died (as others mentioned) but I'd put a test light on there to be sure. Then you'll know what you need to do.
    West Chester, PA
    2001 Camaro SS 1LE
    Thanks FBJ,,,I will look into that.
    I have unplugged the 2 prong plug that clips to the compressor, and plugged it back in to make sure it was tight. I am very light on electrical testing skills. Is there any way you can walk me through how to do the test in laymen's terms? I do not have a test light yet, but I assume it has 2 leads (one positive and one negative?). I'm very good at doing things I have never done before.
    The compressor electrical connection plug, once unplugged, has 2 electrical connector holes in the end. Starting at this point, can you tell me exactly how to perform the test? I could make an educated guess, but would really appreciate it. Thank you.....!
    West Chester, PA
    2001 Camaro SS 1LE
    If I were to make a educated guess, do I put the positive lead of the "Test Light" into EITHER of the two holes in the end of the plug and the negative lead to the engine block, or is one hole, possibly the negative one, the wrong hole to put the positive lead into? Thanks to all those who chimed in, especially on a Sunday afternoon. I AM great with Mechanical work, but as I said, I am a little weak on Electrical diagnosis. Thanks All, and bless you.
    Last edited by NastySS; 06-10-2012 at 12:14 PM. Reason: CLARIFICATION of a few points.
    Arizona
    Should be a 2 wire plug, one ground and one power. Usually the color will give it away. Black ground and power for AC is usually green.
    Either way it's real simple. Unplug it, ground the (clipped) end of the test light to anything that looks like a solid ground. Turn key on and turn on the AC. Take the sharp end of the test light and touch inside the plug (either wire doesn't matter, but one of them should light up the test light). If it doesn't light then rest assured power isn't there.
    I'd probably test power at the low pressure switch too, make sure it's at least getting that far.
    As a side note, jump the battery with the test light just to make sure the light is working
    West Chester, PA
    2001 Camaro SS 1LE
    Thanks AGAIN FBJ, It is a 2 wire plug, and I did notice a Black and Green wire. Your instructions make complete sense to me. I assume the car should NOT be running during this test?
    What I don't understand is what the "Low Pressure Switch" is, and where it is located. I assume the testing procedure is the same. Thanks so much for your help,!
    Arizona
    Correct, engine doesn't need to be running, just key on and AC on should produce power to the compressor.
    The pressure switch is under the hood on the passenger side, right next to the passenger strut tower. Can't miss it. I believe it's attached to the ac line rather than the dryer/accumulator.
    It will also have a plug, power runs through this switch before going to compressor so if there isn't any power at the compressor then this switch is the next place I'd look to make sure it's plugged in, secure, and no wires chaffed.
    West Chester, PA
    2001 Camaro SS 1LE
    Thanks again FBJ. I will look for it. I understand this switch will keep power from going to the Compressor, therefore keeping it from running if the Refrigerant level is too low.
    It is just so perplexing that I had ICE COLD A/C one minute, then warm air the next minute. The guy at the parts counter was sure my A/C Compressor Relay "Popped,,as he put it". He said he has been selling 20 a day recently. I am wondering if I got a bad Relay from the Auto parts store. It was not a GM part, and it was MADE IN CHINA...!!!....YUK,!
    West Chester, PA
    2001 Camaro SS 1LE
    Hey FBJ, I found the Low Pressure Switch very easily like you said, which is attached right to an A/C line by the Passenger Side Strut Tower. It is a 3-Pronged plug with 3 wires (Purple, Green, and Red with a Black Stripe). I assume I test this like the Compressor plug,,,just keep trying (Probably the Red Wire) until the test light, lights up (Or not).
    I still have to run out and get a test light.
    Question, If I did get a bad A/C Compressor Relay, will either of these 2 connections get power? I read on the net about a guy using a paper clip to jump the connections where the relay plugs in, just to see if that makes the Compressor Clutch kick in. That would indicate a bad relay? He also said to be very careful too. With 4 plugs in the relay plug, I wouldn't know where to put the paper clip anyway. BAD IDEA? Thoughts? I am also trying to determine if I got a bad relay from the store.
    Arizona
    Quote Originally Posted by NastySS View Post
    Yes you can jump the pressure switch plug with a paper clip. If there is at least power to that pressure switch plug, jumping that would then send power to the compressor.
    Not sure if either would have power at all if you have a bad relay though. Don't have schematic in front of me, but I tend to think all power has to go through the relay before either of those plugs.
    West Chester, PA
    2001 Camaro SS 1LE
    Well FBJ,,,,,,ARE YOU READY FOR THIS????? I JUST GOT IN MY CAR TO GO TO THE AUTO PARTS STORE TO BUY A TEST LIGHT. After 3 days with no working A/C, I decided to give it a try. The A/C KICKED RIGHT ON,,,,!!!! Right away I pulled over to check the refrigerant level via the fill port (I had a Refrigerant level gauge with me), just in case it was low, and was possibly causing the issue. The needle on the gauge pointed 3/4 of the way into the "Blue "Filled" Section of the Gauge" (The range of the Blue section is 25-45 PSI), so approximately 40 PSI.
    Also, I had the GM A/C Relay back in, not the replacement one made in China I had bought this past Friday. Now I am thinking of the possibility of a problem with the Rotary Dial that turns on the A/C. Let this simmer in your brain for a while. After simmering, any thoughts would be appreciated. Man,,,this is Whacky Monday!!!!
    West Chester, PA
    2001 Camaro SS 1LE
    The only thing I did today, was to unplug then plug back in, the Low Pressure Switch 3 prong electrical plug. I can tell you that it was plugged in securely, and there was nothing unusual like dirt, grease, grime, or a loose connection.
    I have been in and out of the car about 6-8 times today and every time so far the A/C has turned on,,,no problem. I guess I will just wait and see if this situation happens again. For now, I am going to do nothing, no diagnostics for electrical current at specific points like I was planning earlier. OH, and you lied about the 5 dollar Test Light. It was $5.99!!!!....lol
  1. Help: HELP!!! ABS and ASR Stopped Working!!!
    By NastySS in forum General Help
    Last Post: 06-14-2012, 05:52 AM
  2. All my seatbelts stopped working, WTF??
    By UKRAMAIR in forum General Help
    Last Post: 08-30-2009, 08:49 AM
  3. Horn stopped working?
    Last Post: 09-24-2007, 02:35 PM
  4. alarm stopped working
    By blky2kd in forum Stereo and Electronics
    Last Post: 07-18-2006, 12:42 PM
  5. 12 Disk just stopped working...
    By SlickersDrip in forum Stereo and Electronics
    Last Post: 01-23-2006, 06:56 PM
