Results 1 to 2 of 2
    Richardson
    01 TA
    2001 TA Horn not working
    The horn in my 2001 Trans Am doesnt work at all anymore. Before it was random but now when I'm pressing on the steering wheel, nothing. I'm guessing theres a loose wire or something. When I use the keyless remote there is no beep either. When I press the horn or turn off/on the keyless remote I can hear a click in the engine bay but no horn noise. Where should I go about looking for the problem? The fuse and relay is good. Thanks!
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    the horn is located in front of the passenger tire inside the bumper. most likely they are bad.
  1. help with car horn
    By milleniumz in forum Camaro / SS
    Last Post: 09-21-2010, 12:42 PM
  2. Question: Horn not working
    By wdpryor in forum General Help
    Last Post: 08-10-2010, 06:27 PM
  3. horn
    By basballny2 in forum General Help
    Last Post: 10-04-2007, 04:50 AM
  4. Horn stopped working?
    Last Post: 09-24-2007, 02:35 PM
  5. Horn going off
    By 1stgto in forum GTO
    Last Post: 06-22-2007, 04:10 PM
