Thread: horn
10-03-2007, 05:47 PM #1
horn
my horn wont honk.....haha ive pressed it in 120923234954 different spots and it wont wrk.....any ideas?
10-03-2007, 06:50 PM #2
check your fuses, relays...
10-03-2007, 09:27 PM #3Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
There should be an adjustment screw on the horn itself.....grab it with a pliers and twist it back & forth but try to return to the same position as when you started, then try the horn.
Sometimes the weather corrodes the contact.
10-04-2007, 04:50 AM #4Impwnded
- May 2007
- Davenport, Iowa
Bright Red- 1999 Trans Am Ws6
The adjustment screw is covered in a white sillicone crappy material. It is used by the factory to set up the horn, but not intended for you to use, so they cover all the crap over it.
help with car horn
By milleniumz in forum Camaro / SSReplies: 7Last Post: 09-21-2010, 12:42 PM -
dixie horn
By bige97 in forum Multimedia SectionReplies: 2Last Post: 05-03-2008, 06:52 PM -
Horn going off
By 1stgto in forum GTOReplies: 4Last Post: 06-22-2007, 04:10 PM -
99 T/A one horn or two?
By 99'CajunFirehawk157 in forum Firebird / WS6Replies: 19Last Post: 06-21-2007, 09:17 AM -
Horn
By TROYWS6X in forum Firebird / WS6Replies: 5Last Post: 11-18-2005, 08:29 PM
