Results 1 to 2 of 2
    Import Killer camarostripes96's Avatar
    Aug 2006
    academy,tx
    1996 Trans am
    reverse!?!?!?!?!?!?
    Where is the reverse light wires run to and from? and does it have a fuse for the reverse lights?
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    i posted in the other section. there should be light green wires going to the reverse lights. they go to the transmision range switch. from there they are brown and it connects up before the relay for the turn signals. check the turn signal flasher and make sure that it is installed correctly. also check the sockets for the reverse lights. if there is a lot of rust clean it out or replace them.
  1. Won't Go Into Reverse
    By 69er in forum Manual Transmission
    Last Post: 05-26-2012, 11:38 AM
  2. Help: will not come out of reverse
    By Mr.Gomez in forum Manual Transmission
    Last Post: 09-30-2008, 07:56 AM
  3. No reverse
    By ssweet99ss in forum Manual Transmission
    Last Post: 08-30-2008, 02:21 PM
  4. Help: No Reverse!
    By 98_Z28_ls1 in forum Automatic Transmission
    Last Post: 04-06-2008, 06:43 AM
