Results 1 to 17 of 17
09-17-2007, 04:12 PM #1
Big trouble with the slave cylinder on 2000 trans am ws6 n
ok so just 3 days ago, i got A new rebuilt transmission 6 speed. the slave cylinder went out and€ then i got it replaced with a new one. 2 hours later down the road it broke again. so if anyone knows whats€ wrong that would great
09-17-2007, 05:41 PM #2
Might be the master cylinder.
09-17-2007, 05:42 PM #3
Did it break again after driving it hard? Did you make any high-rpm shifts in that 2 hours?
09-17-2007, 08:52 PM #4
no i didnt i wasnt driving it hard in either cases
09-17-2007, 08:53 PM #5
and i shift about 2500 rpms
09-17-2007, 09:54 PM #6
I'd be willing to bet you got internal leakage in the master cylinder.
09-17-2007, 09:55 PM #7
The master isn't too bad of a job to get off. Might be worth checking out. Hardest part is bleeding the fluid when you re-install or replace it.
09-18-2007, 07:50 AM #8
so the master cylinder could make the slave cylinder go bad then
09-18-2007, 03:46 PM #9
09-18-2007, 03:47 PM #10
I know for sure my master cylinder went bad and then my slave cylider went bad right after. It started with my master leaking internally.
09-18-2007, 06:10 PM #11
What do you mean broke? Did it just stop working correctly or it broke apart into 2 or more pieces? Also what slave are you using GM, parts store, ect?
05 PBM GTO
Cold Air Inductions CAI,Relocated IAT with omega,Slp Predator tune,Flowmaster axle back with H pipe,Custom tuned TCM.BC Racing coil overs
Sold 01 z28
09-18-2007, 11:36 PM #12
i got my slave cylinder from car quest. after the first one broke, the shiop replaced it. then 2 and half hour s later the second slave cylinder broke. sorryn im kinda drunk and pissed off bout the car. but i t6alked to fbody motor sports they say it might just be a bad slaave cylinder or the cutch isnt alighmned properally
09-19-2007, 07:47 PM #13
Yeah my two thoughts were either just a crap slave or when the tranny/clutch was installed the slave got messed up.
09-19-2007, 08:35 PM #14
well i just took it to the shop today...i sure hope i get good results, or someone besides me is gonna die.
09-19-2007, 08:35 PM #15
Hope you figure it out.
09-19-2007, 08:38 PM #16
ya hey thanx alot
02-01-2008, 01:24 AM #17
alrighty so i havent been on since september 21st, my bad. to update, it was the clutch that went bad, everything got put back together and is runnin fine now. thanx guys for tryin to help me figure out what the fuck was up with my TA. she drives like a dream and purs like a kitten.
Mastery Cylinder or Slave cylinder problem?
By chris5 in forum General HelpReplies: 7Last Post: 08-02-2012, 10:59 PM -
T56 Slave cylinder
By Baenzi in forum Manual TransmissionReplies: 8Last Post: 02-19-2011, 04:59 AM -
2000 Trans Am WS6 auto trans trouble
By 10874477g in forum External EngineReplies: 2Last Post: 09-12-2008, 05:34 PM -
Which slave cylinder to buy?
By MnLS1 in forum Manual TransmissionReplies: 5Last Post: 03-10-2008, 01:30 PM -
2000 trans am ws6 slave cylinder trouble
By RedFenix_68 in forum Manual TransmissionReplies: 0Last Post: 09-17-2007, 04:32 PM
