12-22-2009, 05:40 AM #1Junior Member
- Oct 2005
- houston, tx
Black- 1999 Camaro SS
Mastery Cylinder or Slave cylinder problem?
99 Camaro SS 6 speed. So anytime i drive hard, i can only shift once, b/c the clutch pedal has to be pumped or i just grind goign into the next gear. It's strange b/c it happens even if i don't shift fast. Ex, be in 2nd gear rolling, floor it, then when i go to shift to 3rd (slowly) i can feel the pedal is already lost pressure and i cant make one shift to 4th unless i put it in neutral and pump the pedal a few times. I just don't understand that once it's already engaged in gear how it gets messed up if i go WOT ....
Any help would be apreciated. Thanks.1999 Camaro SS 6 Speed
12-22-2009, 10:51 AM #2O U 8 1 2
- Nov 1999
- over here...
that is your flywheel glazing over... time for a new clutch and flywheel... also a fluid change wouldn't hurt either...
12-22-2009, 01:28 PM #3Slow'er'Ass
- Thornton, CO
Master and slave.
Sticking clutch pedal is normally the master though. Actually....the line from the master to the slave...it has a restriction in it.
Clutch is probably on it's way out as well.
12-22-2009, 01:58 PM #4Junior Member
- Oct 2005
- houston, tx
why do you all think the clutch is on it's way out though? It doesnt' slip ever when engaged in gear.
i also forgot to mention that i have a lot of trouble shifting into first from a dead stop. I have to either go 2nd to first, or put in neutral, release clutch, then clutch in and then first. it's especially bad when cold.Last edited by chris5; 12-22-2009 at 04:04 PM.
12-22-2009, 03:07 PM #5
08-02-2012, 02:19 PM #6
I don't think is is your clutch I have the same exact problem right not I changed the master it was not that so don't waste the money it's your slave cylinder but u have to drop the tranny so might as well get new clutch set I'm saving money right now for mine
08-02-2012, 04:25 PM #7
08-02-2012, 09:59 PM #8
GM Slave Cylinder?
By Speed_kills_WS6 in forum Manual TransmissionReplies: 5Last Post: 04-07-2010, 12:07 AM -
Slave or Mastery cylinder?
By Blackout01 in forum Manual TransmissionReplies: 4Last Post: 09-23-2008, 05:00 AM -
LS2 slave cylinder
By black2002ws6 in forum Parts Wanted / TradeReplies: 0Last Post: 04-07-2008, 05:45 PM -
Do I need a new slave cylinder???
By slo4mula in forum Manual TransmissionReplies: 8Last Post: 11-17-2006, 11:13 AM -
Which slave cylinder
By pet_monk in forum Manual TransmissionReplies: 0Last Post: 11-12-2005, 03:46 AM
