    Member MnLS1's Avatar
    Jan 2008
    SW Metro, MN
    1999 SS
    Which slave cylinder to buy?
    Okay, my ls1 is slipping, so I', ordering the ls7, w/ ls2 flywheel. So which slave cylinder should I buy. Ive heard the afermarket ones are less restrictive(engage faster), any suggestions will be greatly appreciated!
    Senior Member 01ws6er's Avatar
    The 717
    2001 Trash Can
    Quote Originally Posted by MnLS1 View Post
    Just had the ls7 kit/ ls2 flywheel installed and I got the gm slave from ws6store...$125 dollars and it releases great, and holds like a sum bitch. It's not hard to get into gear when driving hard either.
    Another thing...Have your mechanic (or yourself) replace the seal behind the pilot bearing, in the crank. Mine was cocked sideways, and oil leaked all over the clutch...we had to get one special ordered from a machine shop cause GM doesn't carry them anymore...
    Jan 2008
    SW Metro, MN
    1999 SS
    thanks for the input do you have the p/n for the seal, and what brand? thanks alot, was it the ls1 slave? how much did you pay for the ls7kit and ls2 flywheel about $400? Thanks again
    Member TACE02's Avatar
    ASC #753
    2002 Collector's Edition
    As far as I know, they discontinued the older slaves. The one you get from WS6 store is the 01-02 LS1 slave. Which is the one you need.
    Member WARP211's Avatar
    Feb 2007
    FairField, CA
    RED 35TH ANIVERSARY PKG
    2002 CAMARO SS 35th LE
    I would also like to know which one to get..? I have 02' camaro and my TO bearing is taking a shit so its about time to replace the whole works. I don't really want to put in a stock slave, maybe LS7 one..? Don't know if it will work. Anybody with some positive input is welcome..
    Jan 2008
    SW Metro, MN
    1999 SS
    did you get the new slave too? clutch bearing, replace the rear main seal, or do the drill mod? Thanks im just about to order.
    Last edited by Y2KPewterSS; 03-10-2008 at 08:53 PM. Reason: Removed non sponsor link
  1. Mastery Cylinder or Slave cylinder problem?
    By chris5 in forum General Help
    Last Post: 08-02-2012, 10:59 PM
  2. T56 Slave cylinder
    By Baenzi in forum Manual Transmission
    Last Post: 02-19-2011, 04:59 AM
  3. GM Slave Cylinder?
    By Speed_kills_WS6 in forum Manual Transmission
    Last Post: 04-07-2010, 01:07 AM
  4. c5 slave cylinder
    By 99-SS-Conv in forum Corvette
    Last Post: 04-16-2008, 12:21 AM
  5. Which slave cylinder
    By pet_monk in forum Manual Transmission
    Last Post: 11-12-2005, 04:46 AM
