09-02-2007, 02:05 PM #1Junior Member
- May 2007
- virgina
black- 99 trans am
if you use mobil 1 oils help me out
if you use mobil 1 oils help me out and let me know what blend of mobil 1 you use and how offten you changr it
Thanks
09-02-2007, 03:21 PM #2
i use the reg mobile 1, not the extended miles one. and ever 3000 miles i change
but also to add the mobile 1 isnt what it used to be
09-02-2007, 03:23 PM #3
10w30 ful syn every 3000
09-02-2007, 03:26 PM #4Member
- Apr 2006
- Chowchilla CA
White- 2001 Z28
The best way to help you out is to read Sarge's posts, then switch to Pennzoil Platinum 10w-30. Check your results with oil samples at Blackstone Labs. Your engine will thank you!
09-04-2007, 10:14 AM #5
10w30 full syn. every 2500-3000 ACdelco filter
09-04-2007, 05:54 PM #6
I dont but the 0W40 is the only one I would ever use.
Engine oils?
By Nathan01ss in forum Internal EngineReplies: 21Last Post: 02-17-2010, 06:30 AM -
Motor Oils and Volatility
By CompSyn in forum Internal EngineReplies: 0Last Post: 12-03-2008, 02:01 PM -
Synthetic Oils???
By GraigZ28 in forum General HelpReplies: 33Last Post: 05-08-2008, 10:36 AM -
Mixing oils?
By 98redz in forum General HelpReplies: 21Last Post: 08-22-2007, 05:57 PM -
oils!!
By Ls1fury in forum Camaro / SSReplies: 16Last Post: 01-06-2006, 01:17 PM
