Results 1 to 20 of 22
Thread: Mixing oils?
    canada
    1998 z28
    Mixing oils?
    I just bought my car about a month and a half ago and the dealership i bought it from did an oil change and all that kind of stuff but i was checking my oil a couple of days ago and it could use a little more. I know that ls1's burn oil slowly but i dont know what kind of oil is in it and a local place told me that if its regular oil i shouldnt mix synthetic with it, so my question is if i just add some synthetic oil to top of my engine until i do an oil change is it going to hurt anything or are these guys full of shit?
    Baumholder, Germany
    Green
    94 Camaro 3.4
    Well, if you've got the cash, save yourself some worries and just do another oil change with full syn...
    As for just adding some... I *doubt* you would cause much harm... but to be safe just add the "partial" synthetic.
    Or... ask the dealer?
    MOTOR CITY MARO' SSTODD's Avatar
    LIVONIA,MICHIGAN
    PEWTER
    2000 CAMARO SS #3821
    It is fine to mix, don't worry about it.
    Burlington, NC
    SSTODD is correct. Just top off your engine with the synthetic oil. It will mix OK. Just do it and don't worry about it. The next oil change use the 5w-30 synthetic oil.
    JEB
    canada
    1998 z28
    thanks for the replies everyone i guess ill just top it off with some synthetic. Why do u think i should go with the 5w30? i always thought that your supposed to run 10w30 in these cars. It gets cold in the winters here if that makes a difference.
    Burlington, NC
    Because 5w-30 is the oil that the manif. suggest. However, I run 0w-30 Amsoil year round and it does a great job for me..
    Cedar Rpaids,IA
    1998 Camaro SS
    Just a idea, Ls1s need 5.5 quarts of oil. The dealership might of just put in 5. I'm just bringing this up because it happened to me when I first got my SS. Also don't worry about mixing the oil, but I would use synthetic oil from now on, if I were you.
    1998 Camaro SS Hard Coupe Bright Red #1593
    Mods: Lots!!, still my daily driver except for winter
    383rwhp 370rwft/lbs
    1979 Corvette
    Mods Lots!!, weekend cruiser
    325rwhp and 320rwft/lbs
    2007 Dodge Ram 1500 4x4 (Yes its got a HEMI)
    Mods: Catback, BFI CAI, Winter daily driver
    Member Bouvers's Avatar
    Blue 1997 Trans Am(Sold)
    Pewter 2001 Trans Am Vert
    I figured they used 5.5 I always thought that every 350 gm engine took 5litres I changed it and found that 5 litres wasn't quite enough thanks for setting my mind at ease.
    Retired Outlaw Sum Bitch
    You can mix oils all day with no problems.
    This is my signature. It is mine. Nobody else has one like it.
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Ok im starting to get a little confused. I heard also a few times that you got to keep with the same kind of oil in the car, like if you start off with synthetic it always has to run synthetic and the same for conventional. BTW what is the best oil to run with the LS1?
    LIVONIA,MICHIGAN
    PEWTER
    Quote Originally Posted by JwMonE99 View Post
    That is all a myth, not true. The oil guru Sarge has been talking about Pennzoil Platinum synthetic 10-30 and I switched my last oil change.
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    So everyone is pretty much everyone should use Pennzoil Platinum synthetic 10-30 right?
    Never Drink and Derive Tonik's Avatar
    '99 SS
    I use the Autozone Brand. 5w-30. Its all the same thing. AMIRITE?
    LIVONIA,MICHIGAN
    PEWTER
    Do a search on oil on this site and you will find pages and pages of research on oil and filters to use and not use (FRAM). All oil is NOT the same but most are better than years ago. He asked what the "BEST" was and the wear numbers from used oil anaylsis is what people are quoting.
    d
    2002 z28
    i mix different oils every other day from brand to brand and syn to reg. on my winter car, leaks like a quart .5 a week. i know its not a ls1 but still has over 262,000 miles on it and runs fine.
    d
    2002 z28
    is there a toruqe setting for the oil drain plug or just really tight. next time ill be doing my own changes soo
    Omaha, NE
    2000 Z28 Camaro
    Quote Originally Posted by greatwhiteZ28 View Post
    well i'm no expert but i've done mine twice now...i don't get it too tight and i made sure i can get it off without struggling too hard.
    d
    2002 z28
    soo no torgue
    Omaha, NE
    2000 Z28 Camaro
    soo no torgue
    ehhh maybe someone who knows more knows what it is. sorry dude
    d
    2002 z28
    soo did you buy another car yet? i know you been looking? off topic sorry
  1. Mixing LS3/LQ4 on LQ4 build?
    By kevinr in forum Internal Engine
    Last Post: 12-07-2013, 06:23 PM
  2. Mixing Automotive Paint - Stirring The Pot
    By Ed Blown Vert in forum Corvette
    Last Post: 05-07-2008, 04:00 PM
  3. video mixing, my first stab at it
    By djvaly in forum Multimedia Section
    Last Post: 10-11-2007, 08:52 AM
  4. if you use mobil 1 oils help me out
    By bmwmteam in forum General Help
    Last Post: 09-04-2007, 05:54 PM
  5. oils!!
    By Ls1fury in forum Camaro / SS
    Last Post: 01-06-2006, 01:17 PM
