Results 1 to 1 of 1
Thread: Motor Oils and Volatility
12-03-2008, 02:01 PM #1
As discussed in the Base Oils & Lubricant Performance thread, one area where one can see a performance advantage in base stock characteristics is in a lubricants ability to resist thermal break down. This can be demonstrated by the American Society for Testing and Materials (ASTM) and their Noack Volatility test, otherwise known as the D-5800.
Theory
Originally Posted by Amsoil, Inc. (06/2003)
Base Oil Comparison
A lower Noack Volatility number equates to a lower percentage evaporation loss of the motor oil. Evaporation loss is one reason for having to add motor oil to your car even when there are no oil leaks present. This evaporation loss can also be the cause of a motor oil thickening over an Oil Change Interval (OCI). The ability of PAO base oils to resist volatility break-down can give them an increased value over conventional motor oils due to increased oil change interval capabilities.
Lubricant #1: Conventional Motor Oil
Chevron Supreme SAE 10W-30 API (SM)
API base stock category: Group II
Base Stock Origin: Refined from crude oil.
ASTM D-5800 Noack Volatility: 9.12 (Amsoil test result, June 2005)
Lubricant #2: Full Synthetic Motor Oil
Pennzoil Platinum SAE 10W-30
API base stock category: Group III
ASTM D-5800 Noack Volatility: 9.9 (Pennzoil Typical Physical and Chemical Properties Sheet, February 2008)
Lubricant #3: 100% Synthetic Motor Oil
AMSOIL 100% Synthetic SAE 10W-30 Motor Oil
API base stock category: Group IV/V
Base Stock Origin: Pure chemicals derived from Crude Oil or Natural Gas.
ASTM D-5800 Noack Volatility: 5.4 (Amsoil Typical Technical Properties Sheet, October 2007)
CompSyn
Motor Oils and Cold Temperature Performance
By CompSyn in forum Internal EngineReplies: 0Last Post: 12-03-2008, 01:58 PM -
Synthetic Oils???
By GraigZ28 in forum General HelpReplies: 33Last Post: 05-08-2008, 10:36 AM -
if you use mobil 1 oils help me out
By bmwmteam in forum General HelpReplies: 5Last Post: 09-04-2007, 05:54 PM -
Mixing oils?
By 98redz in forum General HelpReplies: 21Last Post: 08-22-2007, 05:57 PM -
oils!!
By Ls1fury in forum Camaro / SSReplies: 16Last Post: 01-06-2006, 01:17 PM
