Results 1 to 20 of 22
Thread: Stock idle speed
11-07-2005, 08:35 AM #1
- San Jose CA
White- 99 Z28
Stock idle speed
What is the stock idle speed on a 99 a4.
thanks
11-07-2005, 08:44 AM #2
400-500 rpms during closed loop....about 600-700 during open loop
11-07-2005, 08:46 AM #3
- Retired Outlaw Sum Bitch
AC on in closed loop 800
AC off closed loop 600
open loop 700-800
11-07-2005, 09:27 AM #4
- San Jose CA
White- 99 Z28
Thanks guys
11-07-2005, 10:07 AM #5
600 closed loop..shit, my car must be broken...mine idles around 400. Then again I doubt the stock tach is very accurate...whats the best way to get a accurate reading?
11-07-2005, 06:03 PM #6
- cali
- 1990
mine has always idled at 500, I once had an egr leak where it goes into the intake causing it to idle lower than 500 and felt like it was going to die.
11-07-2005, 11:24 PM #7BlackHawk T/AGuest
500-600 here
Stock A4
11-10-2005, 12:30 AM #8
- Oct 2005
- Houston
Sebring Silver- 98 Z28
i'm assuming that this is in drive btw and mine is at about 700/800 in drive w/out ac
11-10-2005, 08:23 PM #9
- Nov 2005
- Orl
Red- 1998 Pontiac Trans Am
mine idles low, 400-500..but i think i need tunning after cam install. (02 zo6 cam)
11-11-2005, 03:34 AM #10sonnyredGuest
Mine idles at 750
11-11-2005, 04:26 PM #11
Originally Posted by sonnyred
11-11-2005, 04:47 PM #12sonnyredGuest
Originally Posted by SeVeReDiStOrTiOn
11-11-2005, 05:12 PM #13sonnyredGuest
Sorry foregot to say its a six speed.A4 may different.
11-11-2005, 09:40 PM #14
- Oct 2005
- Houston
790
11-14-2005, 02:30 AM #15
- San Jose CA
White- 99 Z28
Can someone explain what open and closed loop is.
11-14-2005, 08:35 AM #16
Originally Posted by IRACE2
Closed loop is the condition when the motor is warm....idle drops because all the sensors are telling the pcm that it's warm...the theromstat opens up...pcm uses the o2 sensors for fuel managment.
11-14-2005, 11:55 AM #17
- Jul 2005
- Jacksonville, FL
I wrote down my stock closed loop idle speeds (A4) off my Predator before tuning. Tach was fairly close and steady, but the scanner showed it actually switching back and forth a little:
P/N - 645-676
In gear with foot on brake - 525-585
Might vary a little from year to year too - dunno for sure.
11-14-2005, 06:50 PM #18
- Oct 2005
- Houston
what i need to know is how do i set the correct throttleblade angle or basicly the idle screw setting... i have an aftermarket billet TB but there was no idle screw for it because i had to transfer the screw from the old one to the new one but now i don't know how to set it right because the IAC adjusts alot for the setting on there....i'm just wondering if you hook a voltage meter up the TP sensor and monitor voltage like you would for the idle stop mod...anyways the service manual doesn't say crap about it even for the stock setting....what is the stock closed throttle voltage at the TPS?
11-14-2005, 07:07 PM #19
- Oct 2005
- Houston
also here is the procedure for relearning the idle from the GM service manual:
AUTOMATIC TRANS:
ign. off
remove pcm batt fuse
wait 5 min
replace pcm batt fuse
a/c off
park brake and block drive wheels(do not use brake)
start vehicle
allow coolant to reach over 176F
shift into drive
wait 5 mins
turn on a/c
wait 5 mins
shift to park
wait 5 mins
turn off a/c
wait 5 mins
turn off engine. off
MANUAL TRANS :
ign. off
wait 5 min
a/c off
park brake and block drive wheels(do not use brake) PUT VEHICLE IN NEUTRAL
start vehicle
turn on a/c
wait 5 mins
turn off a/c
wait 5 mins
turn off engine for 30 secs
this should help with many idles
then a relearn driveability cycle should be done http://www.obdii.com/drivecycle.html
02-25-2006, 08:44 PM #20
hope that works...mine has been a steady 1010(approximate) open and closed loop since I got it...no SES, well I did manage to kick it off when I when racing today a couple of times, but then it went away...
What's Your Idle Speed?
By Naaman in forum General HelpReplies: 111Last Post: 01-13-2013, 02:24 PM -
Average Idle Speed
By TransAm11973 in forum General HelpReplies: 12Last Post: 09-02-2009, 07:39 PM -
idle speed
By m1a2d3 in forum Camaro / SSReplies: 8Last Post: 09-15-2008, 12:46 PM -
high idle speed ???
By paq in forum General HelpReplies: 4Last Post: 04-07-2007, 06:50 AM
