    québec
    98 Z28 camaro M6 hardtop
    high idle speed ???
    i've just start my 98' Z28 after 4 month of storing and the motor run too high (2500rpm to 3000rpm) when it's to idle. Before I started the engine , i've polish de MAF and the TB. I expected that i have decalibrate the MAF but after swap mine for my father's MAF, nothing have changed. Do you have an idea for that?
    thanks!
    -paq-
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    check for loose connectors...chances are you didnt plug in the maf senor or something around that area all the way in.
    Member mikeaford's Avatar
    Fredericksburg Va
    01 Trans Am
    Ensure that all the clamps are tight for your hoses to the MAF and throttle body etc I had one clamp loose and it would run then die instead of idling but loose connections will make it do all kinds of freak things.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Like said above check your connections and make sure you didnt break any and all is well. Pull out your IAC sensor and clean it with some crc maf cleaner.
    J
    québec
    Tanks guys! i will check for that today (i'm now at home) and i will cross my fingers for it work propelly!
    -paq-
  1. idle issues... idle high. unplugged tps runs good?
    By okiels1 in forum Firebird / WS6
    Last Post: 12-31-2016, 03:36 AM
  2. Land Speed Racers - High-Speed Bombers
    Last Post: 11-16-2010, 05:20 PM
  3. high shift points & high idle
    By Red 99 T/A in forum General Help
    Last Post: 07-26-2010, 08:04 PM
  4. High Idle..
    By DubisSix in forum Firebird / WS6
    Last Post: 12-10-2008, 02:48 AM
  5. High idle
    By kev70ss in forum External Engine
    Last Post: 01-27-2008, 01:40 PM
